exhaust or something else?
1 Post
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
hello I have an issue I cant seem to figure out. I have hooker shorties 1 5/8 primes to 3" collectors. off that I have 2.5 inch pipe to 3 inch dynomax bullet mufflers. the issue im hearing is when im only at cruise speed 55-65 mph I get a noise out exhaust that sounds like car is having a lean miss. its not lean cause plugs are slightly black. I have timing at 36 deg all in by 3000 rpm. I have a 2800 stall on a 355 sbc. carb is an edelbrock 1405. I only hear the noise when cruising at them speeds. any other speed below is perfectly fine. what gives? any ideas?
Re: exhaust or something else?
It's difficult to tell from the plugs the AFR at cruise unless after extended cruising (say 50 miles or so) you shut the engine off and coast to a stop.,Then read them. Even that is a dubious proposition.
Best bet if you are going to tune any carb is to invest in a wide band O2 sensor and gauge. Then you'll have instantaneous readings.
1 Post
Engine: 355
Yes. Resonance could be the cause. Keep in mind that the state of tune will cause variations in the exhaust note as well. Lean may sound one way, rich another, advanced or retarded timing, something else.
Where does you exhaust exit?
1 Post
Engine: 355
it exits behind the front seats and turn downs toward the side of car
There's a lot to be said for that exit location. I've heard plenty of people complain about it.
Moving the exit as far back as you can will make a difference. If it's possible, try to get the tips to the rocker panel.
I'm guessing you have a muffler that's near the front as well? Try moving it/them as far back as possible too. That will definitely make a difference in how it sounds inside the cabin.
1 Post
Engine: 355
ya ill deff try to move them back. side exit only looks good with boom tubes imo
84 1LE
08-28-2016 12:33 PM
