sticky throttle
Old 10-09-2002, 12:01 PM
irocaz28's Avatar
sticky throttle
I have an 88 iroc 350 tpi. the trottle was sticking so i changed and reset the t.p.s.. While i had the sensor off i sprayed car choke cleaner all around the butterflies to clean off any crap that may have built up and possibly keepin the trottle from closing. i had a lot of black stuff flow out of it. Is that good? After putting it all back together i started the car and the trottle still sticks at 2000 rpm's. when i drive the car and get on it, it takes forever for the needle to go back down and then it sticks at 2000 again. Any advice on what it can be?
Old 10-09-2002, 11:58 PM
86LB9's Avatar
A sticking throttle could be caused by a few things. You said you replaced and reset the TPS and it didn't cure the problem. If you reset it correctly then obviously that wasn't the problem and you just wasted a little dough in the process. Here's what I'd do:
Disconnect all the cables from the throttle body. Check the throttle cable itself to see if there is any resistance. If so, you found your problem. Replace it.
If not, open and close the butterflies manually and see if they close all the way. It's spring loaded so it should just snap itself shut. If it doesn't then the butterfly shaft is extremely dirty and needs to be cleaned or the spring is bad and needs to be replaced.
Other than that, there's really nothing else. You just have to use a little common sense with most of these problems. I usually check everything that may cause the problem rather than just start replacing things. Save time and money that way. If you still can't figure out, let me know and I'll see what else I can do for you.
Old 10-10-2002, 07:55 AM
irocaz28's Avatar
thanks guys. ill give that a shot. I only replaced the tps because a friend of mine brought one and didnt need it. I was with him when he brought so i know it was new, when i told him i had a throttle problem he gav it to me so it didnt cost me anything. ill check the throttle today and let u guys know. thanks again.
Old 10-10-2002, 07:59 AM
fattie92's Avatar
have you taken it off of your car at all? i just had the throtle sticking on my carb, and the problem was that the carb wasnt EXACTLY centered on the intake.
Old 10-10-2002, 05:35 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
real quick how do take the butterfly shaft out of the tb...mine is sticky to..
Old 09-09-2003, 08:45 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
Better yet....how do i replace the Spring on the Throttle Body?
Pac J
05-17-2020 10:44 AM
RedLeader289
05-28-2019 01:47 PM
Z28/ZR1
10-23-2015 01:04 PM
HoosierinWA
10-07-2015 10:15 AM
dusterbd
09-29-2015 08:40 AM
Quick Reply: sticky throttle
