What yall think about the build?
Car: 92 GTA
Transmission: 5 Speed
Axle/Gears: 3.27 posi
Re: What yall think about the build?
looks good get some aluminum brightener for the upper plenum it'll bring it to that bright looking finish on the runners so it all looks new. Just remember to have a hose handy to spray it off immediately. Its pretty much an acid so be careful with it. Looks pretty good otherwise though hope it runs like a beast!!!
Car: stock car
Engine: 350 Chevy
Transmission: 1.76 powerglide
Axle/Gears: 3.73s
oh man does it run. lol after spending a day getting it tuned it will litteraly spin the tires as long as im on the gas. stock 700r4 with stock borgwarner rearend. Its my friend ryans car i did all the work on. but it is an awsome car and is way fast now.
Car: stock car
Engine: 350 Chevy
Axle/Gears: 3.73s
I think imma put a new fuel pump in it to.
Car: '92 Z28
Engine: 350 TPI L98
Axle/Gears: 10 Bolt / 3.23
Is that a 305 or 350 block and Edelbrock heads and plenum plus runners atop?
Looks nice!
Looks nice!
How about a break down on the parts. Part #'s, Cam info, etc. 350??
Car: stock car
Engine: 350 Chevy
Axle/Gears: 3.73s
And yes its a 350 idk why any one would spend 3400 dollars on a 305. it has Edelbrock performer heads 2.02 int 1.60 eht max 575 lift. also has scorpion 1.6 full roller rockers. also has comp cam full roller 525 int 530 eht 106 lobe sep 300 int durration 310 eht durration. also has edelbrock performer TPI base and runners. Accel injectors. Holley throttle body. headman headders. that is everything.
