type of hose for fuel injection
Old 12-17-2011, 12:48 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
hey everyone whats up
i have been using rubber fuel injection hose lines for my FIRST TPI intake.... the hoses are rated at 50 psi... i was wondering which hoses should i use for my custom fuel lines under the hood... i dont want to have to worry about the lines leaking or bursting and causing a fire under the hood.... i think im using 5/16 hoses and using 6 an connectors.... can anyone give me a link to hoses are are in the 20ft range... thank you for your help.
Old 12-17-2011, 12:52 PM
Vader's Avatar
Re: type of hose for fuel injection
I've had good success using Goodyear Injection Hose, SAE specifications J30R9 & GM 6163. Goodyear 65152 is 5/16" (25' Spool) and Goodyear 65153 is 3/8" (25' Spool). Irt's rated @ 100 PSIG and is resistant to gasoline, alcohols, and additives.
Old 12-17-2011, 01:01 PM
88fastgta's Avatar
thank you so much man.... would rubber hoses be fine for under the hood.... i need about 5 inches of fuel line hose to connect the fuel rails together for the FIRST TPI... also i gotta have 4 feet hose for each side of the rail to reach the afpr and the line going to the gas tank...
jhawkeye
05-25-2022 06:33 PM
midge54
12-27-2019 04:14 PM
9192camaro
16
02-03-2019 12:21 AM
Fast355
12-02-2016 06:33 PM
86Base
08-13-2015 05:06 PM
Quick Reply: type of hose for fuel injection
