tuneing my irocz need help!!!
Old 04-12-2013, 03:35 PM
mikes89irocz's Avatar
Hey guys if anyone has any kind of info on programming proms or have done it on theirs I have a 5.7l tpi irocz 700 r trans the previous owner put a can in it I don't know what type or dur. It has but my car has a cold start issue and when its warm it starts with no problems I have back track all sensors all are getting the appropriate voltage and are clean and operating correctly I just need an example or what you programed it at thanks guys
Old 04-13-2013, 07:42 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: tuneing my irocz need help!!!
This is a question that should be addressed in the diy prom section. Sounds like you may have another issue like injectors or bad ect. If you need to make a change in the $8D mask you should address the startup enrichmenment vs coolant temp.
Luigytico09
10-01-2015 08:46 AM
Quick Reply: tuneing my irocz need help!!!
