need help switching from a 5.0 to a 5.7
Old Apr 14, 2013 | 11:41 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I know that I have to change the computer and the knock sensor but is there anything else that I have to change.
I bought 24lb injectors
Old Apr 14, 2013 | 11:43 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: need help switching from a 5.0 to a 5.7
Just the chip, knock sensor (I don't use them on maf cars) and injs. 22lb is stock.
24s are ok, just make sure u swap it in the tune.
Old Apr 14, 2013 | 12:51 PM
jamon8's Avatar
Engine: 350 tpi
I am comparing the two at autozone.com and it looks like the egr valve is different and the electronic spark control module is different
do I have to change these or will it be ok
Old Apr 14, 2013 | 12:57 PM
landon360's Avatar
Car: 1986 iroc-z
Engine: 350 tpi.
Transmission: 700r4 with shift kit
Axle/Gears: stock gearing
i just changed my car from 5.0 to 5.7, and learned the hard way that this stuff needed to be changed as i was told by the mechanic that is was all ok to still use in the 350, what im changing now is the chip, injectors, knock sensor and the ESCM (the egr valve as far as i know can be used for both)
Old Apr 14, 2013 | 01:21 PM
jamon8's Avatar
Engine: 350 tpi
so I replace the computer, injectors, knock sensor, escm and the chip. cool I dont want to just throw parts at the car but I want to replace what is nessesary
Old Apr 14, 2013 | 02:21 PM
landon360's Avatar
Car: 1986 iroc-z
Engine: 350 tpi.
yeah and all that should be around $400 depending on where you get the injectors and parts thats how much i spent
Old Apr 14, 2013 | 02:33 PM
TTOP350's Avatar
Search feature is wonderful. Here is one. I'm guna go look at my 305 and 350 cars to see.
https://www.thirdgen.org/forums/engi...lectronic.html
Old Apr 14, 2013 | 03:05 PM
jamon8's Avatar
Engine: 350 tpi
where is the electronic spark control module. I will have to go take a look
Old Apr 14, 2013 | 04:05 PM
landon360's Avatar
Car: 1986 iroc-z
Engine: 350 tpi.
mine is behind the break booster on the firewall
tglennon11
Sep 23, 2015 05:30 PM
IROCtometal
Sep 20, 2015 11:08 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
