88 5.7 tpi bouncing idle and stalling
Old Sep 2, 2015 | 02:04 PM
IROCtometal's Avatar
Car: 88 iroc-z 350 tpi
Engine: 350 tpi
Transmission: 700r4....for now....
Axle/Gears: 9 bolt 3.27
Hey guys,
I have an 88 5.7 that has recently began acting quite strangely recently. When I first start the car cold, it will start right up, but after the idle settles down a little, the idle speed will bounce between about 400 and 1200 rpm. This will happen endlessly until I start to drive the car. Under acceleration above 1000 rpms, the car runs really well, but when I lift off to change gears (t5 swap a few years ago) or let off to come to a stop, the rpms plummet to almost 250 rpm, then slowly the idle will come back up to normal (700ish) after about 10 seconds
Old Sep 20, 2015 | 09:22 PM
MrPackstin's Avatar
Car: 1989 GTA
Engine: 5.7 w/Paxton
Re: 88 5.7 tpi bouncing idle and stalling
Sounds like it is "hunting" which is related to the IACV.
Old Sep 20, 2015 | 11:08 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
I second IAC, could also be spark related
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
Bryan F
Aug 18, 2015 02:28 PM
Sanjay
Aug 12, 2015 03:41 PM
