Why would I not have more hp & torque after a 305 TBI to 350 TPI swap
#101
Car: '89 Camaro RS convertible
Engine: 5.7 TPI
Axle/Gears: 4.10
Re: Why would I not have more hp & torque after a 305 TBI to 350 TPI swap
I would take great heads all day long over 13 cid. On avg. most street type performance engines will only avg. out 1 to 1.5 HP per cubic inch.
So going from a 360 to a 383 is only 13 cid and will only gain you 13 to 20 HP.
A good set of heads will gain you 40-80 HP over your stock ones. Like say a set of vortec heads, you are looking at around a 35-45 HP gain. A set of Brodix IK heads around a 60 HP gain, a set of AFR heads around a 70-80 HP gain.
Heads are the #1 highest hp gain part (other than nitrous, turbo, supercharger) you can add.
#102
A 383 even with stock heads will make more bottom end torque than a 350 with good heads. I'm talking 3000rpm and below. If I were in your shoes I guess I'd go with the stroker and stock heads. You can always change the heads out later.
#103
Engine: 5.7 TPI
Axle/Gears: 4.10
I decided to go with the stroker. I had my transmission rebuilt and it ended up being less than what originally quoted so maybe I can get some heads to.
#104
Engine: 5.7 TPI
Axle/Gears: 4.10
Anyone have any suggestions on a good cam. I was planning on using a comp cam just not sure which exact one I should go with.
#106
Engine: 5.7 TPI
Axle/Gears: 4.10
The 268 is the one the builder suggested but I had the wrong part number so comp cam told me it wouldnt fit my block and they suggested the 260 one I'm buying roller tip rockers and springs if needed so I'll probably go with the 268 but comp asked if I need a small base circle cam for the 383
#107
Engine: 5.7 TPI
Axle/Gears: 4.10
I just bought an engine that was already built from a friend that wrecked his car. Its a 355 full roller high flow runners edelbrock heads. Now im not sure if my exhaust will fit with the extra quart oil pan or the oil cooler. I can probably modify the exhaust to fit the pan but do I really need the cooler?
