Fuel Mileage issue?
Car: 1991 z28 L98 Spec
Engine: 5.7 350 TPI 245\345
Transmission: 700 R4
Fuel Mileage issue?
Can runs amazingly, only down side is a code 42 that wont go away, will be checking it out tomorrow. Also only gets 13.5 mpg on the interstate?
Any suggestions guys?
Car: 1992 Z28 Camaro
Engine: 350 tpi
Transmission: Built 700r4
Axle/Gears: 3:42
Re: Fuel Mileage issue?
The 91-92 camaros had a fuel tank issue that was recalled, but few were fixed. If you smell a strong smell of gas for awhile after filling up, it may have a leak and need to be fixed. Not saying this is your problem, but its something to take a look at.
1 Post
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Code 42 is related to ignition advance. This could be the main cause of poor mileage. Lack of advance causes an incomplete burn of fuel.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
If you adjust the base timing, you will get a code 42. Try adjusting the base timing to the factory spec. Then unplug the battery for 5 minutes. Re-connect and see how things go.
colton_carlson
03-08-2019 12:21 PM
NBrehm
08-25-2015 11:49 PM
