tpi swap problem
Re: tpi swap problem
Ops switch is correct I think relay may have been bypassed as it seem to be switching on and off as it should but fuel pump runs continuously following another post l spliced g4 pin at c100 and ran a wire to pin b on c207
How is the rest working out? Can u give me more info on the swap? I have a 1991 rs that I did 1988 mass air tpi swap. My ADAL pors dose not function nor my guages? Any help is appreciated. Thanks
The relay for the fuel pump was bad replaced it and the pump and it runs fine only guage not working is speedo just haven't hooked it up had to rep in bulkhead connector to match body
NBrehm
08-25-2015 11:49 PM
Sanjay
08-12-2015 03:41 PM
