1.6 roller rockers
Car: Trans Am gta 5.7 1989
Engine: 350 tpi
Transmission: th700r4
Axle/Gears: BG 9 bolt
1.6 roller rockers
Hello
Will i gain som HP if i change to 1.6 roller rockers? And do i have to change anything else ?
The engine is Stock 5.7 tpi with hooker 2055 headers.
Re: 1.6 roller rockers
Im hungry. If I eat food will I not be hungry?
You will HAVE to use lock-nuts rather than the stock rocker nuts and you will HAVE to use Valve Covers that will fit over the Rockers / Poly-Locks.
As long as you buy the correct rocker arms, you should not HAVE to replace anything else or HAVE modify anything else to install them on a stock SBC 5.7. ( If you are building an engine - there's more to it then just buying "bolt on" rockers. )
You should gain a couple HP - don't expect to feel it.
KO1
16
10-15-2015 05:00 PM
