Which Intake Manifold Gasket Set for TPI?
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
When I did my MAF TPI swap on my Monte Carlo SS with 350 motor and Trick Flow 175cc alum heads, I think I used fel-pro 1205 intake gaskets. Since that is what Trick Flow recommended for their 175 cc heads. Now I read that fel-pro 1205 is the wrong intake gasket for TPI and will cause a vacuum leak. I have two questions: 1) Is it true that fel-pro 1205 is the wrong intake gasket for TPI? 2) What intake gasket should I using? Thanks
Re: Which Intake Manifold Gasket Set for TPI?
I can't make a specific recommendation.
When I installed an Edelbrock 3860 many, many moons ago I had read someplace that the only intake manifold gaskets to use were Fel-Pro Print-O-seal gaskets and to stay away from the blue Perma-Torque ones.
I probably used the Fel-Pro 1256. Stock heads, exhaust cross over, etc.
You can find the Print-O-Seal gasket part numbers here:
http://fme-cat.com/PerfApplication.aspx?app=perf
Car: 1986 IROC Z28
Engine: 87 Small Block Roller Motor
I have the Trick Flow Heads and used the 1205 gasket. Works fine.
Transmission: 2004r
Thanks for your replies guys. I kept the box the gaskets came in and found it yesterday. Apparently I used Fel-Pro #MS930351, which is the part number specified for 85 - 92 TPI F-body.
Car: 1986 IROC Z28
I'm running a port matched stock intake.
86IROC112
08-17-2015 02:00 PM
