Injector question
Car: 87 Camaro IROC-Z 5.7 TPI
Engine: 350 aka 5.7L Tuned Port Injection
Transmission: 700-R4
Axle/Gears: 3.27 posi
Injector question
Are these injectors any good? They are 24 pound Bosch out of a Mustang I believe, I have looked at a lot of the threads and it's kind of confusing because there are no pictures or part numbers that I can find
1 Post
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Re: Injector question
If they OHM correctly 14-16 . If you are running factory injectors #19-#22 you will need a chip to run the#24's.
I have the Holley commander 950 ecu. I just put in a 355 so I will be adjusting fuel tables accordingly. Unfortunately looks like they sold me denso injectors as Bosch injectors and shaved the part number off so I'm trying to get my money back. I need a nice set of 24s but it's hard to find what part number I should get.
We have them in stock. Give us a call if you're interested. TGO members receive 10% off
