1.6 rockers on modded tpi
1 Post
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
I'm looking to replace my 1.5 roller "tip" rockers with full 1.6 rollers.The engine been modified and wondering would I need to change anything.Or can I just slap them on and call it a day? The heads are aluminum dart pro 1 200 heads.has guide plates and double valve springs.cam is the crane 2032 also running the stock length harden steel push rods.So would I be safe changing to 1.6 rockers?
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: 1.6 rockers on modded tpi
without looking up the head specs, as long as they will handle the increased lift you should be fine. i'm using 1.6' on my 2032
propaintball96
04-12-2016 01:30 PM
