New rear main seal?
Old 01-16-2017, 05:40 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
New rear main seal?
It looks like the rear main seal on my motor needs to be replaced. Will the engine need to come out to do this? Are there any upgrades, maintenance, or preventative maintenance that can/should be performed while having this done?
Old 01-16-2017, 05:41 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: New rear main seal?
You can replace it bye removing the transmission.
Old 01-16-2017, 10:58 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
The one thing you might consider (depending on mileage and cooling system health) when the engine or transmission is out is to replace the freeze plugs in the back of the block.
