no computer and a 700r4?
Old 02-22-2006, 01:46 PM
streetphase.com's Avatar
Car: 92 Camaro
Engine: 305tbi
i have a 92 camaro and a 700r4 i ripped out and the computer wiring harness including the connector that goes to the tranny... someone told me that without that hooked up the tranny won't shift. if im not mistaken its for lockup only and that the tranny will operate just fine without being plugged in. correct me if im wrong.
Old 02-22-2006, 02:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yes, the computer has no control over the transmission. It will shift just fine without a computer. You'll need to pick another way to control the TCC though.
Old 02-22-2006, 02:55 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
it will shift but you won't get the lock up function which is going to KILL your gas milage + build a lot of heat as a result of the slipping converter which will wipe out that tranny in a hurry.
Old 02-23-2006, 01:53 AM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
You'll need to pick another way to control the TCC though. What does TCC mean? An how would you control it? I'm changing my car to a holley 950 commander wire harness and was wondering will it control my 700r4?
Old 02-23-2006, 11:32 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
TCC is the torque converter clutch. It needs to be locked while cruising in 4th to reduce heat. I don't know if the Holley Commander can handle it, but there are a number of other ways to do it.
Old 02-23-2006, 12:53 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The Holley C950 will not control the TCC. You will need to get a kit from TCI, Hughes, Painless, etc. to control torque converter lockup. I have seen an article in a post somewhere here o TGO about pressure switch that can be installed in the valve body to lockup in 4th gear.
Old 02-24-2006, 02:02 AM
xurusaibobx's Avatar
Car: 1991 Camaro RS B4C
Engine: 5.7 350 TPI
get a bm
theres different kits
i have a B&M TC lockup kit ...was 170 bucks, you can lock up the tc whenver....
but theres also cheaper kits that do it with out no manual option
Old 02-24-2006, 01:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Just about every kit can have manual operation if you add a $0.69 switch.
Old 02-24-2006, 04:38 PM
Engine: 5.7 350 TPI
this one car change the when the tc locksup..its speed controlled
Old 02-24-2006, 08:39 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
http://bowtieoverdrives.com/catalog/...AT&CATID=OA1A3
Old 02-25-2006, 03:48 AM
Car: 87 IROC
Ok so if I get the botieoverdrive kit for $70 and a 69cent switch it will do everything the B&M kit will do? When should the switch be turned on when racing? Is that what you mean by manual operation?
Old 02-25-2006, 10:41 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Manual operation means you can flip the switch and have the torque converter locked or unlocked any time you want.
Old 02-26-2006, 05:17 AM
Pro Built Automatics's Avatar
Problem with the BTOD's kit, is that if you go to WOT, and there is to much load, or no downshift, you will fry the torque converter clutch. Use the GM vacuum switch which will automaticlly lock & unlock when needed, based on vacuum.
rs_z28_vert
09-30-2015 09:47 PM
92projectcamaro
09-29-2015 07:07 PM
IROC ZELLER
09-29-2015 03:00 PM
Damon
09-26-2015 04:29 PM
6998poncho
09-25-2015 02:56 PM
Quick Reply: no computer and a 700r4?
