T5 FAQ - Everything we know about the T5
#51
Car: 85 Z28
Re: T5 FAQ - Everything we know about the T5
So Im assuming they are externally the same so that a wc t5 would be a direct bolt in upgrade for a non wc t5, correct?
#53
I GOT A 1357-071 FROM A JUNK YARD AND PUTTING TO BEHING MY 350 BLOCK IS THE TRANS WORTH USING OR IS JUNK AND IF SO WHAT WILL I
HAVE TO CHANGE TO MAKE IT WORK?
#54
According to the chart near the beginning of this thread, an 071 model is a V6 trans. A V6 trans is definitely not worth running behind a V8. The ratios are crap for use with a V8 motor. In addition to that, you'd have to get a custom clutch disc that's the correct diameter (10.4") with a special 14 spline hub. The V8 T5's use a 26 spline input shaft. Your best bet would be to sell the V6 trans on ebay and put the money towards a V8 trans.
#55
I just thought I'd add this. I have broke several T5 transmissions in my 4X4 S10 (with a '94 Camaro 3.4 and SFI). It's a little hard to find 4X4 T5 transmissions, so I have converted several T4 transmissions into NWC T5s. There are some T4 transmissions that have the extention on the counter shaft that allows you to add 5th gear to it. By changing the internal shift linkage and the extention housing you can make it a T5.
#57
#58
Car: 85 Z28
seeing as theres confusion on what fluid to use in the non-wc t5 Im wondering, has anyone tried synchromesh? Im thinking its similar to 5w-30 and it seems someones used just about everything else. Im just wondering if it might be a happy medium between gear oil and atf. also its been said synthetics should be avoided, is that just when using atf or for all fluid? thanks
#59
Car: 1988 IROC
If you unit has a tag bolted to the tailhousing these #'s represent world class units:
Three Digits of Part Number: 1352-XXX)
114 thru 116, 126, 134, 141, 155, 162, 165,
167 thru 169, 174 thru 177, 184, 194 thru 200, 202 thru 205,
207 229, 238, 247, 248, 249, 251, 254,
258, 260
#60
Guys I need some help. I'm replacing the fluid for the first time on my WC T-5.
I need to know the fluid capacity, because I cannot remove the fill plug, even after soaking it in WD-40. Whoever tightened it on last really did it - I put a breaker bar combined with a fat 2 foot pipe for leverage and it WOULDN'T EVEN BUDGE =[
#63
Car: 1982 Chevy Camaro
Engine: 355 sbc built
Transmission: 350 turbo
Ok. I have read a good bit of info in this area, but I have a few more questions that I did not see asked. If they was asked I missed them, anyways. First question is, Compared to a TH350, is a T5 the same length? And second question is, The bar that goes from tail shaft of the transmission to the rear end, will it bolt directly to a T5?
This is the deal, I want to swap my automatic for a straight drive. What is the best route? I have a 1982 with a 350 bored 0.030 over with a TH-350 turbo. The car was a 305 with a 200 metric. Any help would be appreciated.
#64
The bar from the tailshaft to the rear end is the torque arm, and yes it is the same for 700R4's and T5's. I do not know if its the same for TH200's and Super T10's.
One problem with the torque arms is the direction of the rounded part, also called the "lips". Some torque arms have the lips facing the left side and some face the passenger side. You'll need to pay attention to this when getting the torque arm mount on the tailshaft.
#65
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
are any special tools required to rebuild a NWC t5? bevause i read something somewhere that you need some kinday pulling thing to rebuild a t56 so i want to make sure before i buy a rebuild kit...
#66
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
You don't need the endplay tool like the T56, but you do need access to:
Depth-micrometer or good dial caliper
Bearing separator and press
Large snap-ring pliers
Rebuild Manual
#67
Car: 1989 Camaro RS
Engine: 2.8l v6
could i use a v8 first gear and a .63 overdrive gear with my v6 trans? i dont like the short first gear, and would like the better overdrive... and i could get those, but i dont know what snap ring pliers are?
thank you!
thank you!
#68
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Axle/Gears: factory 9 bolt with 3.45 gears
#69
Car: 1991 RS
Engine: LO3 (305) / 4.8L LS
Axle/Gears: 4EU 3.27 Posi
Wanted to know if a T-5 tranny from a 2000 firebird v-6 will fit in a '91 305 with a t-5.
My t5 is crap (wont shift to second and fading fast).
i can get this tranny for under 200.00
Will this swap over easy. Can someone point me in the right direction.
#71
Car: 1991 RS
Can anyone verify this ??? and are you talking about the bell housing?
Can i buy or make an adapter (cut and weld my bell housing (engine side) to the new bell housing (tranny side) ???
#72
Car: '91 Trans Am GTA / '83 Camaro
Engine: 383 SBC / 430 Buick BB
Transmission: Tremec TR-3550 / TH-400
Axle/Gears: Stock 10-bolt, 3.42 /10-bolt
The bolt pattern that is on the trans case where it mounts to the bell housing is different. Also, I learned from this thread that the 4th gen V6 T5's input shaft is a tad longer as well.
Here's a good line up of a bunch on the different bell housings from over the years:
http://www.tacreationsusa.com/bell_housings.htm
#73
I have some questions:
1.) Is the bolt pattern on the T5 case the same for all V8 as well as V6 3rd gen T5s? So that, ignoring the spline count difference, could you bolt a V8 T5 into a V6 and vice versa(IE: will a V8 T5 bolt to a V6 bell housing and will a V6 T5 bolt to a V8 bell housing)?
2.) Other than the spline count difference, are the 3rd gen V6 and V8 T5 input shafts the same length? Does anyone have a depth measurement for a stock V8 T5 bellhousing from the engine mounting flange to the transmission mounting flange?
3.) Is the diameter of the part of the input shaft that engauges the pilot bushing the same diameter for a V8 and V6 T5?
Thanks!
Thanks!
#74
Car: 91 camaro RS
Transmission: t-5
i wanted to know if you could help me with this i ran into this problem i seized my t-5 in my camaro and i bought a used t-5 off of a guy on MIFbody and when i had it put int this pressure plate did not fit i think it was too small but there is not metal tags on it all i have are all the cast number i wanted to know if anyone could tell me what this t-5 came out of i was reading what all they put them in so the guy i got if from said he pulled it off his 85z28 that had a 350 in it and he did not know if the trans was original i don't think it is so here are the cast numbers
top# 13-51-097-901
left# 13-52-069-907
right# 2dl236666
Sticker#wd13-52-027612n_ _4
These are the numbers the shop gave me. Hope you can help me out. Thanks
top# 13-51-097-901
left# 13-52-069-907
right# 2dl236666
#75
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
First off -use punctuation so us older folks can understand WTF you're saying.
Second - if there's a 350 AND a T-5 in a Camaro or Firebird, one or the other (maybe both) isn't original.
Third - I can't figure out what you're asking. do you need to know which pressure plate you need? or do you need to know part numbers? what are you asking for?
#76
top# 13-51-097-901
left# 13-52-069-907
right# 2dl236666
top# 13-51-097-901
left# 13-52-069-907
right# 2dl236666
#77
Car: 1982 Trans Am
Engine: 383 chevy
Pat - not to hijack, but if he's running (numerically) low gears, like say 2.73s, wouldn't a 3.50 1st gear be ok? I could have my math backwards, which is why I'm asking. the steeper gearing in the smaller-engine T5s was specifically to counteract the tall gears of the other models, I thought.
#78
#79
Car: 1982 Trans Am
Engine: 383 chevy
sweet. good to know the desert hasn't TOTALLY fried my brain yet.... looks like if I want the better gears I should check the 4 cyl and 6 cyl cars with manuals, eh?
#80
The transmissions with the 4.03 and 3.50 first gear are going to be much weaker than the 2.95 transmission. Also, the 4 cylinder and 60 degree V6 transmissions have a longer input shaft than the V8 transmissions, so they won't mate to the bellhousing before the input shaft bottoms out on the crankshaft. There was a 14 spline clutch disc used in the 4.3 Astro van that will work with this transmission, but you must do some modifitcations to the input shaft and front bearing retainer to make it work.
#81
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Since I'm actually running the V6 T5 behind a 350, I'll add my .
The clutch disc that Pat Hall and Big Gear Head are referring to is from an 82 GMC S15 with a 2.8L V6. Part # at Autozone is CP4201, it has the 14 splines and is listed at 9 11/16" diameter.
Centerforce used to make a 10.5" 14 spline clutch disc for S10 V8 conversions but Summit apparently doesn't carry it anymore.
You could also try a disc from an Chevy Astro Van with the 4.3L V6, but it's an 11" clutch so I'm not sure it will fit inside the pressure plate.
As for transmission modifications, you need to cut about 1/4" off the front of the input shaft. I also used my angle grinder to chamfer the leading edge of the input shaft like it was originally. That is the only change I had to make to the transmission to get it to bolt up.
First gear is very short as was mentioned, I find myself shifting almost immediately into 2nd with 3.42 rear gears.
#82
If you're worried about the desert frying your brain, I'm assuming you don't live in FL anymore? Where I'm at, I'm so sick of the heat I can't wait until Oct. so I can actually go out and wrench in the garage comfortably! But yeah, the 6 cylinder cars are a sure-fire bet for finding 3 series rears. Good call above on shortening the input shaft. I forgot all about that. There was a guy who posted up some time ago, with pictures and everything on how to go about shortening it. He also listed the funky clutch disc that's needed.
#83
Car: 1982 Trans Am
Engine: 383 chevy
nope - FL is still home, but I'm in Iraq ATM. 5 more months and I'll be finishing my engine. I did the tranny swap (the hard parts anyway) before I left, because I had the time, tools, lift, an parts. it wasn't very difficult at all, and I can't wait to try it behind the 383. I read through this thread a lot to make sure I had everything needed and when I didn't, I found what I was missing.
as for the funky clutch and shortening the shaft - bigger cojones than meself! I'm not so sure I would've attempted that, meself!!! kudos for making it work. the chamfer was probably a good idea, too.
#84
Car: 1992 Camaro RS
I did a LOT of reading on here and researching part numbers/clutch disc sizes before I finally settled on my setup. Unfortunately, I didn't know about the input shaft length until I was trying to bolt the transmission/bellhousing to the back of the engine. I figured it was hung up on the pilot bearing and kept tightening the bolts until I cracked the bellhousing at one of the alignment pin holes.
The cutting/chamfering was not difficult, it took me about 5 minutes to do with my angle grinder. The hardest part was figuring out how much to take off. I used a cutoff wheel about 1/16" thick and cut it right behind the original chamfer so that I shortened it by the length of the chamfer + the thickness of the cutoff disc. Then I chamfered that edge back about 1/8" at roughly a 45* angle.
The only issue I have noticed is that the clutch will slip a bit if I stomp the gas. I haven't done it that much seeing as the engine was just rebuilt and I'm still breaking it in and trying to tune the carb. I'm not running a hugely powerful engine though. Power estimates in Desktop Dyno are around 300HP and 385 torque.
#85
Car: '89 IROC-Z
Transmission: WC T5
Has anyone put a MGW shifter on their T5 in a camaro? http://www.mgwltd.com/mustang_shifter.shtml
#87
Car: '89 IROC-Z
Transmission: WC T5
Well, I have heard a lot of good things about that shifter and have ordered one. The people from MGW said it should bolt up to any T5, the just were not sure how the shifter **** would line up in the cabin. I should have it in a couple days. Will post progress if any.
#88
Guest
Posts: n/a
I always find new stories of the Ford guys using the T5 from the 2.3L Mustangs in their 5.0 cars because of supply and demand, and most of them hold up to the torque, just not the powershifting and clutch dumps from dead stops. I got in a bind with a 305, so I tried the T5 from an '85 Camaro 2.8L. the 3.50:1 first wasn't too insane, and the 0.78:1 fifth was better than no OD at all, and it held up for nearly 3 years. Also, your gear ratio info on the Ford V8 versions is missing these details: Sometime around '83, The 5.0L Mustangs switched from the 3+1 manual trans to the T5 with 2.95/1.94/1.34/1.00/0.73 ratios, the same ratios as the mid-'83 through late '84 305 F-cars. The '85 5.0L Mustangs all had the above T5-V, And that continued through '88. The '89 Mustang 5.0 got the World Class improvements, and a new second gear ratio of 1.99:1 and a new third gear ratio of 1.333:1. All '85-'93 5.0L Mustangs with T5 had a 3.35:1 first and a 0.68:1 fifth, NO exceptions.
#89
Ok im new to this thing and was wondering if you could answer a question for me.
Im getting an 88' firebird with a 2.8 V6 automatic. I was wondering what kind of transmissions came with those?
#90
#91
Car: 85 Z28
is it possible to swap a 0.73 5th gear from a nwc into a wc with a 0.63 5th?
#93
Car: 85 Z28
I have a 0.73 5th now, and I feel like 0.63 would be too big of a drop
#94
Car: 85 Z28
Transmission: WC T-5
Axle/Gears: 3.42 drum
OK, After loosing third and forth gear on my WC T5 ,and unable to find a sutable replacement for less than $600. I ordered a master rebuild kit and did it myself on my kitchen table. Took alot of photos for refernce and was very happy with the outcome and the price. Finall verdict was the third/fourth syncronizer keys had busted and tore up the syncros. Shifts like new now. I even powdercoated the trans case in extreme crome, the bellhousing black, and the crossmember red while I had it apart(looks awsome!!) The trans had 180,00 hard miles when it broke and now is ready for. For the record I have never rebuilt a manual trans before but am very mechanicly inclined and very determined. Good luck to all and happy shifting
#95
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
I only followed the info in this thread and didn't follow all the links posted, but....
I feel this is something that may be helpful to answer when speaking of the T5 trans and those who may have a pile of parts.
Can a NWC housing(s) be saved for spares(for whatever reason ) to be used on a WC version if needed? Are there any differences to the case/tailhousings themselves from the NWC to the WC other than the internals?
Thanks.
EDIT: There are definately differences in the machining of cases/tailhousings so the case cannot be swapped from a NWC to a WC but the tailhousing from a NWC will work on a WC as long as the NWC oiling funnel is also used when swapping onto a WC unit.
Thanks.
#96
Car: 88 Camaro Silver and Black
Engine: 350 4bbl.
Transmission: World Class T-5
Axle/Gears: 3.42 with eaton posi unit
f-body v8 input shafts are 26 spline on the input and 27 on the output shaft
#98
Car: 2006 Chevrolet 2500HD
Engine: Duramax
Transmission: Allison 1000
Will a B and M shifter base from a t5 out of a mustang work on my 1984 t5 in my camaro?
The bolt pattern looks the same. I have a few custom short handle shifters that I can head and bend.
#99
Car: 84 camaro
Engine: 72 chevy 406 sbc
Axle/Gears: 3.42 eaton posi
ok i just started reading this and according to gm the t5 is only rated for 260 trq and the 88-91 is rated for 300 torque,and thats why they didnt offer this trans with the 350 motors. so what will this really handle? i got a 406 just guessing on hp to be bout 400 or so i got 3.42 gears and eaton posi. will this trans hold up to this power? i have a t5 from a 86 z28 with a 305 and i wanted to swap trans into my 84 sport coup with the 406 thanks for any replies
#100
Honesty, you'd be pushing your luck using the T5. I'll give you the usual response to this question. Yeah it'll hold up as long as you drive it sensibly. They die a very quick death if they're powershifted or subjected to high rpm clutch dumps taking off when behind a healthy SBC, and a 406 definitely has some stout torque. I ended up buying a Tremec TKO 5 speed for mine so I can abuse it without having to worry about grenading it! Most guys either upgrade to the TKO or the T-56 6 speed.
