T-5 build
Old Mar 2, 2009 | 12:49 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
T-5 build
those of you that build your own T-5, are there any special tools needed or can i use some make shift tools? everything i drive has a T-5 so it would be feesable for me to learn how to build them.
Old Mar 2, 2009 | 01:09 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: T-5 build
To do it correctly, you need a gear puller/press, bearing splitter, a depth micrometer, dial-gauge, if those are special enough.
Old Mar 2, 2009 | 01:27 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: T-5 build
kool deal. well they are special enough, i dont have any but i have access to all of it and eventually will have my own. thanx much.
Old Mar 2, 2009 | 07:16 PM
big gear head's Avatar
Re: T-5 build
I've built a bunch of the T5 transmissions and the press, bearing seperator and a set of 6 inch dial calipers is all the special tools that I remember needing. You'll need some snap ring pliers too. Contact Rockland Standard Gear for a rebuild manual.
Old Mar 2, 2009 | 07:45 PM
85MikeTPI's Avatar
Re: T-5 build
You can download the Service Manual directly from Tremec.
http://www.ttcautomotive.com/English...0-0199_173.pdf
Old Mar 3, 2009 | 12:43 AM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: T-5 build
thanx much guys. my 89 came with a .73 final drive and when it started going south i found another 5 from a fella parting out his 89 IROC, his car got the .63 final gear and brother let me tell ya that thing is sloppy compaired to my .73 final case.
NO umph what so ever in 5th and i miss that. iv got a few sources for gears so thats no sweat. a friend went thru his 56 and said a 5 cant be all that hard compaired to a 56.
Old Mar 4, 2009 | 01:59 AM
irocv28's Avatar
Car: 1988 IROC
Re: T-5 build
All i remember was needing a press and snap-ring pliers. perhaps this is why my transmission has been leaking lately. However, the rebuild was 5 years ago now
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
ZEEYAA
Apr 16, 2023 08:29 PM
PurelyPMD
May 5, 2016 04:57 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
