700r4 Compatability
Old 02-28-2008, 06:08 PM
michael's Avatar
Car: 1991 Formula
Engine: 6.2 383 TPIS Miniram
Axle/Gears: Moser 9" 4.11
700r4 Compatability
Will a 700r4 from a 87 2.8 camaro work with a 92 305 camaro. I know the bellhousing is part of the transmission casing and can't be changed, but the rear shaft can be swapped out to retain the electric speedsensor. I'm just wondering if the bellhousing bolts are in the same place and are the same number.
Old 02-28-2008, 09:55 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Re: 700r4 Compatability
Yes, but I would try to find an 89 or newer year transmission.
Old 02-29-2008, 07:34 AM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
I'm not 100% certain, but 95% sure that the 2.8 and a V8 have different bolt patterns to the engine.
Old 02-29-2008, 11:35 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
No, the bellhousing bolt pattern is completely different on 60* V6's and 90* V8's. Also, the V6 trannies are not built with as many clutches and plates as V8's so they are weaker. You need to find a V8 700R4.
loud91rs
10-05-2015 10:05 PM
92projectcamaro
09-29-2015 07:07 PM
IROC ZELLER
09-29-2015 03:00 PM
indygene
09-26-2015 11:21 AM
6998poncho
09-25-2015 02:56 PM
Quick Reply: 700r4 Compatability
