Aftermarket tranny cooler
Old 07-23-2013, 11:15 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Can I install a B&M tranny cooler without having it run through the radiator tank? Or does the tranny need some heat?
Old 07-24-2013, 04:57 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: Aftermarket tranny cooler
Its best to run it through the radiator as well. I believe i had mine hooked up so that it ran through the aftermarket cooler first, then into the radiator to get a bit of heat back and then back into the trans. My trans never saw above 195* after the cooler. Do a quick search on here though and double check that my memory is correct. Its been a few years since my car was auto.
Old 08-03-2013, 02:39 PM
Roger that. Thanks for the reply man.
bjpotter
10-04-2015 07:48 PM
FormulasOnly
10-02-2015 05:52 PM
Quick Reply: Aftermarket tranny cooler
