9 bolt
Car: 92 Camaro Convertable/ 68 Camaro SS
Engine: 305 TBI
Transmission: Auto 700R4
Axle/Gears: 86 TransAM posi rear. 342 gears
9 bolt
How rare are the Borg Warner 9 Bolts?
I bought a 86 TA years ago for the posi rear. I had a shop swap it out for me about 5 years ago.
Last night I went to service the rear and found out my new cover want fit. I was like WTH i dont understand. But i did notice the other night working on my torque arm that the rear had a borg warner cast on it.
So last night I googled BW camaro rear. Well there it was 9 bolt rear. I never knew of these
How rare are these things?
Re: 9 bolt
Short answer - they're not rare.
They were put under a lot of IROCS/trans ams/GTAs/Formulas (I may be wrong on some of my firebird assumptions but anyways...) They started putting them in around 86...I think?
They are stronger than the factory 10-bolt but parts are more expensive (as they are kind of a sole-source deal).
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: 9 bolt
There are many many threads on the 9 bolts and what it takes to rebuild them but if you're not going to do it yourself it could get very expensive. Usual advice is to get a 10 bolt because parts are cheaper and easier to get. 4th gens also have 10 bolts and sometimes better posi units but the axle is wider so that's another issue.
UltRoadWarrior9
09-02-2015 08:24 PM
