rear end leaking / noises
Old 08-01-2015, 04:10 PM
Pemberton76's Avatar
I just got my hands on an 86 z28 with a 350 swap so I'm new to these cars. today as i was driving i heard grinding noises as i was slowing down and it also chirps when being slowed. When i went to inspect the rear end i saw fluid leaking from lines that go in to the rear diff. Can someone please help on how to fix these problems.
Old 08-01-2015, 04:33 PM
big gear head's Avatar
Re: rear end leaking / noises
There are no lines that go into the rear end. What you are probably seeing is the brake lines.
Check the pinion to see if you have any free play up and down or in and out. Many times the pinion nut will back off and allow the pinion to move around. This usually causes the pinion seal to leak.
Old 08-01-2015, 04:57 PM
Thanks i will check that out but any idea on the noises while slowing down.
Old 08-01-2015, 05:15 PM
Yes, that's why I suggested checking the pinion. When you slow down the ring gear pulls the pinion into the housing, which will cause it to make contact with the differential if it's loose.
Under acceleration the pinion is pushed forward toward the transmission.
Old 08-01-2015, 07:33 PM
thanks for the help I'm gonna be replacing it tomorrow
hectre13
12-11-2023 08:14 AM
B_Dubya
08-26-2015 05:09 PM
hectre13
08-26-2015 08:17 AM
mizz0313
08-12-2015 06:45 AM
BlackBoulder
08-11-2015 11:15 PM
Quick Reply: rear end leaking / noises
