305 TPI to 350 TPI swap.
Car: 1987 Iroc-Z
Engine: 350 tpi
Transmission: 5 speed std
Axle/Gears: 3:73
I am swaping a tired 305 TPI to a 350 TPI soon. Before I start, I currently have a stock 5-speed manual transmission. Will this tranny be able withstand the change to a 350? I don't plan on going crazy HP wise with the 350. Only shooting for about 330-350 HP. I am on somewhat of a budget. If it will not work, can I do some mods to the current tranny or will I need a completely different one?
1 Post
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Re: 305 TPI to 350 TPI swap.
There are no mods that I'm aware of that can make a T-5 stronger, the weak link is the case. Weather or not it will hold is kind of a gamble, but the general opinion on here is if you drive it nicely it'll be fine, if you put drag radials on the back & try to launch it you'll blow it up.
Car: 1991 RS
Engine: 5.0
Don't side step the launch or power shift it and it will live. Soon as you start beating on it you'll be replacing it.
1 Post
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
i have a 400 sbc in front of my t5 trany. granted mine is a World Class t5. and it has held up great.
Car: 1987 Iroc-Z
Engine: 350 tpi
Axle/Gears: 3:73
Car: 1987 Iroc-Z
Engine: 350 tpi
Axle/Gears: 3:73
