1991 Camaro RS automatic transmission fluid capacity
Old Nov 24, 2015 | 05:30 PM
'91CamaroRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: 4 Speed Automatic
It's a 1991 Camaro RS 305 with the original automatic transmission (not sure what it exactly is) in it. I drained the old fluid out,put new filter,and gasket in. I looked up how much it takes,and they said 5 quarts. I've only put 4 in so far,but it's showing "full hot." Now I haven't checked it with the car on yet (which I know I'm supposed to do),but I'm worried that if it's showing full hot when it's not even hot if it will be too full when it is hot. Is there something I'm missing here,or am I right and it's too full?
Old Nov 25, 2015 | 12:01 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: 1991 Camaro RS automatic transmission fluid capacity
The level is lower with engine running, trans pumping and ATF at normal opt temp.
Filled right, with engine off and cold, the fluid level will be over an inch above the full hot line.
You are fine. Crank it up and let it run for 20 min and check. I bet you will still need 2 qt to fill it
Old Nov 25, 2015 | 12:32 AM
Car: 1991 Camaro RS
Engine: 305 TBI
You were right. Thank you!
Old Nov 25, 2015 | 02:35 AM
Car: 1988 Camaro
Your welcome, glad I could help.
norcalz28
Jan 16, 2017 03:37 PM
TonysBird
Nov 28, 2015 10:00 AM
Fishy4Life
Oct 29, 2015 07:25 AM
lee01
Interior Parts Wanted
Oct 7, 2015 02:39 PM
SteelheadBen
Oct 3, 2015 12:08 PM
