aftermarket ac belt size
Car: 84 z28 h.o./ 92 rs
Engine: 305 h/o /3.1 v6
Transmission: hybird turbo 350/t5 bog warner
Axle/Gears: non posi 3.73 / ls 3.42
do any other guyz know the ac v-belt size
for non ac cars with after market ac ?
my car is a 92 camaro 3.1 v6 with a wynn's/ frostemp box
with a zexel compressor ?
thanks in advance
thanks in advance
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: aftermarket ac belt size
You'll have to take the belt to a place where it can be measured as there is no part number for the belt on that aftermarket system except for the shop that installed it.
My car didn't have a belt for the ac !
That's why I wanted to see if anybody
Knew the size of the belt !
When I get my car back ill just take the whole car
to the parts store and find the right belt !
It just goes around the compressor and the
outer ring on the engine damper ?
Iam onny askin bc I have a small black plastic pulley
That seems to go to nothing ?
Engine: 2.7L V6
Axle/Gears: 4.41
I forgot about it not having a belt... That small pulley, if it's on the side where the compressor is, is probably the tensioner for the compressor belt. In which case, you'll need to take the car somewhere and test fit belts (after you run around the pullies with a wire or something to get a rough estimate on the size of the belt).
Thanks again mav !
