Going for 10.99 on Motor
Old Nov 14, 2002 | 09:04 PM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Transmission: TH350 4500 STALL
Axle/Gears: 3.73s
Going for 10.99 this weekend on motor..Thinks its possible?
Ive been 11.21@123.7 on a 1.59 60ft in high humidity .Opened up. Im going to open it back up this weekend and i have a new set BFG DRs to help me out.So im hoping for some cold weather to get that 10.99..Or really close...Maybe change to 10sec91Z .lol
Old Nov 14, 2002 | 09:18 PM
rezinn's Avatar
I already registered that name, sorry dude.
Old Nov 14, 2002 | 10:03 PM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Axle/Gears: 3.73s
ok
Old Nov 14, 2002 | 10:22 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
I wish you luck sir.
Old Nov 14, 2002 | 10:27 PM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Axle/Gears: 3.73s
Thanks........
Old Nov 14, 2002 | 10:37 PM
Bort62's Avatar
Well, Good luck on that one.
Take a Healthy one Before you run, hahaha.
Your gonna need some pretty favorable conditions to pick up .3 At that level, but its not unheard of.
WHen you get towards the traps, lean forward... lol
Old Nov 14, 2002 | 10:46 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: 9", 4.33:1
Yeah, no eating until after the track day from here on out!! And be sure to take anything and everything out of the car that can be easily removed!
Good luck though!
Old Nov 14, 2002 | 11:03 PM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Axle/Gears: 3.73s
Ok guys enough of the fat jokes..lol..im 195lbs..Jeeze. i have actually played around with removing the seats..I have never done anything to reduce the weight on this car..Im going to weight it tommorow at the track to see how porky she is..But ive always said i wanted this to be a 100% street car too..So im kinda
torn on the weight reduction thing..But well have to see.. Thanks for the good luck fellas
Old Nov 15, 2002 | 12:14 AM
rezinn's Avatar
Take out all your seats and your jack and spare tire and tools, that's a good hundred pounds at least. Everything helps! Your time slip will say 10.xx, but it won't say your car was stripped
Old Nov 15, 2002 | 01:35 AM
BikertrashDude's Avatar
good luck
it's one thing to strip your tools,
and another to go ape and strip the A/C, seats, carpet, liner, etc
good luck again...
....you are running low 11s and with a stock suspention?
didn't think that was possible....
biker
Old Nov 15, 2002 | 01:05 PM
Bort62's Avatar
Tell that to Madman.
8.75 on the stock style supension.
Old Nov 15, 2002 | 06:00 PM
LETHALRACER's Avatar
Hey 11sec91Z. Do me a favor and throw some street tires on that bad boy for a pass. I want to see if there is much of a mile an hour difference. I say street tires would loose about three mph. Any way, good luck. With that mph you should be able to run 10.85.
Old Nov 15, 2002 | 09:20 PM
BigMike92Z's Avatar
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
heres a trick a friend of mine would use sometimes in bracket racing to pick up those extra couple hundredths...
when he got to the finish line he'd smack/release the breaks real quick and bring the front end down and the front ground effect would break the beams and stop the timers.. probably wont help but i thought it was a decent idea...
Old Nov 16, 2002 | 12:49 AM
esams's Avatar
With necessary weight reduction, it's of course possible.
With weight reduction and an a perfect Yank or Vigilante stall converter over the ACT, it's PROBABLE.
With weight red, the perfect stall converter, and full traction mods, its GUARANTEED.
I honestly think you can get 3 tenths by just faxing Mike Senia at Yank your dyno graph and elevation, and telling him you want maximum ET. He will build you a converter from HELL! Something with say.....2.7 STR and a launch right at your torque peak, that is perfectly matched to your gear. It'll be a bit less streetable, though.
I say that because I got 7 tenths on street tires in my C5, with a ***** soft hitting street converter. That guy squeezes more efficiency into a torque converter than almost anyone in the world from some exotic materials. But then again, you'll need ET Streets to do that, since your drag radials would spin misserably. Then again, with ET Streets, your 10 bolt would pop instantly as well.
Happy launching...we'll be following! Your setup and results are freakish bro. Good luck
Old Nov 17, 2002 | 01:04 PM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Axle/Gears: 3.73s
Well fellas i got rained out today..So no chances this weekend..
I was able to get a new personal best of 11.39@119 with a 1.59
60ft on friday night..this is closed up on street tires no weight reduction other than spare tire removal..so im very happy with that..
ESAMS :MY Art Carr 3500 works well as you can see with my shortimes..but like you said ive heard the Yank converters are awesome but some of the LS1 fellas have problems with longevity...But a 4000-4500 would probably be awesome.Im going to make some changes this winter and that will probably be one of them..
Lethal: BFG DRS are street tires
Anyways gonna have to wait until next weekend to open it back up..ill keep you guys posted
Old Nov 17, 2002 | 01:22 PM
You know what I mean! Put some 4.11 in there. That will keep you in your power range. That is amazing that your exhaust costs you four mph.
Old Nov 17, 2002 | 06:00 PM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Axle/Gears: 3.73s
Well the exhaust slows me down so much because it is still the factory set up dual cat system(gutted)going into a single 3 inch pipe with a dynomax bullet muffler..So when i open it up it really breaths..Which explains the big difference...I cant wait to get long tube headers on the car so it will really breath on the big end
Old Nov 17, 2002 | 07:08 PM
True Power's Avatar
Have you ever dynoed?
Old Nov 17, 2002 | 07:33 PM
Do what I did. 1 3/4 LT Hookers, X-Pipe, dual 3" all the way out. I can't believe how your car 60fts on that stock syspension. I could cut 1.70s on some Nittos on the old motor. That thing only trapped 85mph in the 1/8. I still couldn't hammer it though.
Old Nov 18, 2002 | 12:30 AM
89ProchargedROC's Avatar
Do you already have a set of longtubes yet?
my friend has a set of coated ones for sale
email me if interested
koby12@ureach.com
Old Nov 18, 2002 | 03:17 PM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Axle/Gears: 3.73s
Yea i have plans for headers and better exhaust this winter...Maybe after Christmas.lol I have never dynod my car but i would think it would be in the 410-430 range at the wheels..Also need to weigh it ..
Old Nov 18, 2002 | 05:13 PM
Bro, 3,550lbs puts you at 450-460rwhp at 123mph. That is 576 at the crank with a 20% loss.
Old Nov 20, 2002 | 09:35 PM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Axle/Gears: 3.73s
500HP91Z? :hail: .....................lol
Old Jan 10, 2003 | 01:45 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
Know this is kinda an old thread, but curious if you ever go that time? Also, you got any pics, sounds like you got a sweet ride.
Old Jan 10, 2003 | 07:38 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
damn
dude wtf????? that is awsome times!!!!!! if i had that on motor i'd soil myself!!!!!
i hope for 11's on motor and 10's with a 100hp shot... i have hedman longtubes with true duals and a flowmaster crossover h pipe..... hers a pic... i gaurentee .3 reduction from what your running if you do this.... i'll bet money on it with anyone here i'm so confident that it will help you that much..... you have alot of hp now it just need to breath a little more....... imagine n20 on that sucker!!! one word damn!!!
Old Jan 11, 2003 | 02:13 PM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Axle/Gears: 3.73s
No due to weather conditions here they shut the track down on the last day ..so i have to wait to march to try...
Badgta: lol i know i have alot of potential left in the car..its been kinda fun sapping every bit of E>T out of this thing with the setup i have now..I definately plan on this year doing more mods,But i still will try to sap a 10.99 out of her before i do any further mods..
Old Jan 12, 2003 | 10:10 AM
slp_firehawk's Avatar
11sec91z? could you post your setup in detail?
Old Jan 12, 2003 | 10:20 AM
vwdave's Avatar
11SEC...
Do you know a guy with a 73 lemans running high 13's? His name is Steve.
Old Jan 12, 2003 | 10:40 PM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Axle/Gears: 3.73s
Ok heres the details:
92 L98 block..383
Callies crank
Callies 5.7 rods
Ross pistons
TPIS ZZX camshaft
1.5 Roller Rockers
AFR 195cc cyl head
1000 CFM TB
TPIS Miniram
F.P 54 psi
Stock injectors..
Stock fuel pump
TPIS Level 5 prom
Hooker 1 5/8 shorty headers
Gutted cats..Dual cat car
Single 3 inch pipe with Dynomax bullet muffler.
Exits rear of car..Not a side pipe or turn down
Art Carr 3500 converter
3.73 rear..10bolt
stock suspension..no front swaybar
energy suspension trans mount
Everything else on car is still stock..still has a/c..stock radiator..stock interior..this will be a 10sec all street car
ok i think thats it.lol
Old Jan 12, 2003 | 11:40 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Great results with what you have listed there IMO. Very nice work. Hope you exceed your goal. Later
Old Mar 3, 2003 | 11:30 AM
how is the streetability of that car 11sec? i have my motor apart for my 89 gta and am toying around the idea of just doing a budget vortec 12 sec street/strip car, or going about same route as you, miniram with afr's on 383....only problem is i wouldn't have a trailer available to get the car up to the track, and closest track to me is about 2 hours away, half highway half back roads. then of course money is another issue.
jason
Old Mar 3, 2003 | 04:46 PM
I have the same combo with larger heads and injectors and more compression. I am also running 1.6rr. I drive my car every day. I have no problems with it at all. On the stock converter with a lean condition and street tires with the distributor breaking up at 6,100 ( worn out gear) I went 118.83 @ 3,640lbs. I have the gear fixed now and the Vig 3,200 back in. I will make a trip to the track in a week or so. I will post a new thread with the times. I don't have tires yet so don't expect any great ET's. But the mph should be up there.
Old Mar 3, 2003 | 04:51 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
F.P 54 psi
Stock injectors..
Stock fuel pump
DAMN!!!! All that power on stock fuel pump and fuel injectors, good for you. Any concerns there, especially with 54 psi for FP? Way to put together a good setup and make it work. :hail:
Old Mar 3, 2003 | 05:04 PM
what compression do you have lethal? and any idea what 11sec is running too?
Old Mar 3, 2003 | 05:30 PM
I have 11.2:1. I have a full mod list but it is long. I will post it if need be. I think 11sec is running 10.0:1. Not sure though.
Old Mar 3, 2003 | 05:32 PM
can you post it? or email it to me at jasbak3609@aol.com, whichever would be easier for you, also what times are you getting?
Old Mar 3, 2003 | 06:48 PM
CHRISMAN2000's Avatar
Car: 1991 Camaro Z28
Engine: 350 L98
Hey 11sec91z. Hows the zzx cam? Do you find it a pain to drive on the street?
Old Mar 3, 2003 | 06:58 PM
I have the same cam and it is very streetable. Here is the list.
Short Block
Speed O Motive All forged 383, 4 bolt w studs
11.2:1 compression
Eagle crank and 6" rods.
SRP pistons, and Speed Pro rings, gapped for 150 shot
Clevitte Bearings
Milodon Oiling system, Pan, Pump, Pick up, Diamond windage tray
Summit SFI damper, SFI Flex plate
Cam
TPIS ZZX Hyd Roll
240/240 @ .050 .596/.598 112 lobe sep
Crane Gold Race RR, 1.6
Comp retro roller lifters
Cloyes Hex adjust double roller timing chain w Thorington bearing
Cloyes cast alum timing cover, built in cam button, quick change
Comp race push rods
Vacumm resivor can with guage
Heads
Ported AFR 210, 2.08/1.60, 58cc
REV valves 30* back cut
Comp 950-16 springs, 10* locks, retainers, and cups
ARP 7/16 rocker studs
AFR Hydrarev kit
int. flow...........exh. flow
.600...298.6.....600...235.5
Iduction
Accel 58mm TB
TPIS Miniram, Port matched to 1206
Custom CAI
Fuel
Custom braided feed lines
Ported TPIS fuel rails
AFPR
Seiman 36lb injectors (brand new)
Walbro intank 255
Set up for external T-Rex (have it on shelf)
In car fuel pressure guage w isolator
Ignition
MSD digital six
MSD pro billit distributor (brand new)
MSD race wires
MSD coil
Power Master 140amp alternator (brand new)
Hooker Long tubes 1 3/4, ported to match heads
Dual three inch w X-pipe
Dual 3" Afterburner mufflers
(have two 3" Random Tech cats, still in the box)
Computer
7730 ECM (brand new)
Craig Moats Memcal adapter
Craig Moats ZIF socket
TPIS stage V Prom (piggy backed)
Pocket programer
Three EEPROMS
Auto X-ray (I havn't even received it yet)
Be Cool 4 core Alum radiator
Victor jr water pump
High flow 160 stat
New hoses
Transmission
Pro Built 700-R4
7,000 rpm capabilities
WOT 4th gear shifts
H/D imput drum
Warranted up to 650 hp ( six months left)
Vigilante 4,000 stall
Chassis
Lake Wood 70/30 front struts, 50/50 rears
Eibach Drag Launch Kit w RR air bag
Richmond 3.73 ring and pinion
Misc.
March alum under drive pulleys
TD Tall polished alum valve covers
Shift light, water temp, oil pressure, fuel pressure guages.
I have forgotten some stuff but you get the point.
__________________
Old Mar 3, 2003 | 09:21 PM
Engine: 350 L98
What are you running at the track Lethal racer?
Old Mar 4, 2003 | 05:41 PM
On street tires. I have run 12.03 @ 117 on the Vig when it was slipping like 21%. On the stock converter on the street tires I went 12.66 @ 118.83. But the distributor gear was hashed and breaking the ignition up at 6,100. I also had to shift into O/D at the 900ft mark. I got the Vig fixed and all the other little problems fixed but havn't been to the track yet. The enteresting thing with the converters was that the busted Vig had 4mph on the stock converter in the eigth. But the stock converter had two mph on the top end breaking up. I was gaining thirty mph in the last 1/8. On the busted Vig I put down 350rwhp and 452rwtq at 12.9afr at 3,900rpm. The hp didn't go up from there and the tq fell off like a cliff. Loosing all power by 5,600. The stock converter made 386rwhp and 384rwtq at 14.9afr tq and 13.9afr hp at 6,000 and 4,200 with the ignition breaking up after that. That was all before I had the valve springs replaced and took the heads off due to leaking head gaskets. I did a nother valve job and cleaned a lot of crap out of the heads and pistons.
I am guessing it will make 430rwhp and 500rwtq with all the stuff right and a good afr. It should run low 11's at 122-123. I will let you guys know when I get to the track and the dyno again.
Old Mar 26, 2003 | 02:34 PM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Axle/Gears: 3.73s
Bringing this one back up fellas cuz im goin for it again!!!!!
I have made 2 changes..
#1 hooker long tube 1 3/4 headers 2210 s
#2 4.10 Gears
I finally broke my 3.73s so i thought i would step it up a bit..
And i got tired of my crappy header setup holding me back...
I never got to make a decent shot at the 10.99 last year due to weather here so this is why im bringing this back up..
Old Mar 26, 2003 | 04:13 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Good luck. Let us know how the long tubes work out for you. Recently i had read somewhere that when on an LT1, they made little to no difference for one guy. I am curious to see if you were to get a decent gain from the new mods. You should be there though. good luck
Old Mar 26, 2003 | 05:59 PM
nitrovette's Avatar
Car: 73 corvette
Engine: 2004 ls1
they are some great times already cant wait to see what you run now,good luck
Old Mar 26, 2003 | 11:55 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
that is one very fast car u got the 11sec91z! i think ull break tens, thats one bad mother ****er!
Old Mar 27, 2003 | 08:14 AM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Axle/Gears: 3.73s
Thanks guys ...I have my fingers crossed...and hoping for a good tail wind
Old Mar 27, 2003 | 12:15 PM
Engine: 350 L98
Man try springing for a set of et streets or something.
Good luck. Better order that 10sec license plate soon.
Old Mar 27, 2003 | 01:07 PM
camarorsguy's Avatar
Whats up guys,
good luck man
I need to talk you guys about this exact subject.
I have an 89 Iroc Z 305 tpi w/ 700r4.
I have 50/50 koni shocks in the rear.
3.73 posi
edelbrock short headers
arizona 1000cfm throttle body
msd 6 al
blaster 3 coil
weld rims w/275 60 15 in the rear (street tires)
my question is.....what can I expect to run the the 8th mile?
I have never drag raced before and my friends are talkin trash and it is time to put up or shut up i guess.
I know you guys are gonna ask why I have 50/50 shocks and have never dragged. well i had them given to me and just put them on....that made a huge difference in my takeoff from lights.
Old Mar 27, 2003 | 01:36 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
get rid of that 1000cfm throttle body, WAYYY to big keep the stock 48mm.
hmm 305TPI 700r4 with those mods
14.7-14.9 dont know what that translates for an 1/8th mile
Old Apr 8, 2003 | 12:58 PM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Axle/Gears: 3.73s
Update.
Ok this where im at after the new mods
best ET 11.30....
Best mph 121.00
Best 60 ft 1.58
These numbers are closed up on street tires..I have yet to open it up ..I also am getting some serious wheel hop...so i have not been able to try to leave real hard yet...Im going to swap shocks this week and hope it helps and play around with air pressure on the Drag radials to calm down my wheel hop...Im hoping for some 11.10s closed up if i can get it to leave right..The headers and gears definatley put it deep into the low 11s...not sure if the 10 is there though?
Old Apr 8, 2003 | 03:15 PM
SLP_GTA's Avatar
11sec91Z
Impressive times, did you follow TPIS recipe? seems like a proven set up.
what gears are you running? Also I know a relocation brakets would do you a world of good for hooking up.
