Series2 series3 question.
Old Jul 22, 2003 | 08:54 AM
Cynsguy's Avatar
Some here say that series 3 gears can be put in a series 2 carrier. I remember reading that this parctice would leads to rear end failure due to the difference in gear sizes between the series. What is the story? Can the be interchanged? I have a 273 rearin my 82, so I have more than a passing interest.
TIA
Old Jul 22, 2003 | 10:01 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
No way!
Old Jul 22, 2003 | 10:03 AM
Dewey316's Avatar
Car: 1990 Camaro RS
they are not 'interchangeable'
but.....
richmond and other aftermarket gear makes make steeper gears (3.23 and above) for a 2 series carrier. you can also get a spacer ring to install 3 series gears on a 2 series carrier. this does not go the other way. you can NOT install 2 series gears on a 3 series carrier.
Old Jul 24, 2003 | 06:43 AM
IHI's Avatar
IHI
Dewey is correct, I took a 2 series rear because it had a posi unit in it and 3.08 gear, then took another 3.42 1 legger with disc brakes. Got a ring gear spacer from a company in Las Vegas and installed the 2 series posi into the 3 series rear end. Held up great-but my ring gear finally let go as can be seen in another post in this forum.
ZZ3Astro
Aug 13, 2019 12:57 AM
fbodyfreakls1
Oct 6, 2015 06:34 PM
corey8084
Sep 17, 2015 02:56 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
Ian Irvine
Sep 4, 2015 08:08 AM
