cuts out at >1/2 throttle when warm
hey all,
i ran a search and read of some similar symptoms, but didn't come across an answer, so here goes... my car starts up & runs for about 5 min just fine. once the engine hits ~180º, it will sputter if i give it more than 1/2 throttle or so. if i accelerate really slowly it acts normal. all gages read normal, and no codes.
the first time it did this the other day, i pulled over at a gas station to check it out, and it wouldn't restart. i took the air cleaner off & could see fuel spraying into the TB (it's TBI). so, i thought it had to be spark. got a ride home, came back the next day, and it started right up. drove 5 mi down the road & it started doing the same thing.
my first thought was fuel pump or filter, but i've replaced both in the last 20K or so, and why would those be affected by the engine temp? like i said, it runs PERFECTLY until warm. next thinking it had to be timing advance, but i replaced the distributor (w/ module), plugs, cap, rotor, and wires about 3k ago. only thing still there is the coil. again- why only once warm?
maybe the O2 sensor? some mentioned the MAF, but i don't think mine has one... TBI is based on MAP only, right? ummm... reaching here- timing chain? any ideas?
thanks for any help...
:hail:
Trace
:hail:
Trace
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
check it for codes
is your check engine light on??
if yes id be willing to bet that one of your sensors has gone bad get the codes form the computer and replace/fix what it tells you is bad.
Re: check it for codes
He said no codes...read it again. To start, check your plugs & wires, especially your coil wire. I once had a bad coil wire, once the car got warm it would run like garbage, spitter and sputter and sometimes stall out..and it would only fire up again 50% of the time. If it's not that...check back and we will give you some more idea's. I just don't want to overwhelm you with information just yet.
Terrell351
06-13-2021 01:13 PM
theshackle
09-17-2020 08:26 AM
