HSR and throttle cables?
Old Sep 1, 2003 | 05:34 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Okay, I have another minor issue I encountered today. When I installed the plenum to test fit everything, I found that the stock throttle cable is too short. When I attached it to the TB, the throttle plates would not close all the way on there own. I would have to push the throttle closed and it will reopen slightly without pressure. The throttle cable looks very stretched.
Has anyone else had this happen? I ran a search and did not find any discussions of throttle cable issues with HSR installs. I did find a few pics of some of the guys around with HSRs and all of there throttle cables look fine.
HELP ME!!!
Old Sep 1, 2003 | 06:06 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
not me. buy there are some with the newer TB (i think 89-up) where the linkage hits the plenum. some grinding will take care of that.
Old Sep 1, 2003 | 06:15 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I encountered the same problem...here's what I did.
Under the gas pedal bracket there is a piece of metal that extends from it and the gas pedal rod (where the throttle cable attaches to) will be resting on it...it's more or less a pedal stop.
Bend it slightly forward until you can fully close the throttle on its own, works great! HTH's.
Old Sep 1, 2003 | 06:55 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Thanks for the advice, I'll try that in the morning.
What does "HTH" mean?
Old Sep 1, 2003 | 07:51 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
HTH = hope that helps
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
L0tuS
Oct 4, 2015 08:07 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
