Kickdown cable wont hookup after new carb.........
Old Feb 27, 2004 | 04:22 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
Transmission: 5 Speed
Axle/Gears: 3.70 Posi BW 9 Bolt
I put a holley avenger on my motor bought the holley kickdown stud part# 20-40 and the kickdown cable bracket #20-95 now im clueless the bracket looks like it doesnt hookup any where and the stud is like 1/4 in diameter and dont know where it hooks up on the carb i really need some help i can get sum pics if needed. Also i have the stock intake manifold.
Old Feb 27, 2004 | 10:29 PM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Re: Kickdown cable wont hookup after new carb.........
The 20-95 bracket bolts to the carburator flange over the left rear stud...however, I seem to recall that the offset is wrong. I use a factory GM bracket off of any Carburated LG4 Camaro\Firebird and it works better than the Holley piece.
The 20-40 stud is correct. Edit: There is a projection at the very bottom of the throttle linkage with about a 3\16" hole. You may have to file out the hole slightly to fit the 20-40 stud. Cable goes there and just snaps on stud. You must use a kickdown cable off of an 1982 thru 1986 carburated LG4 car ( FI cable different ). Then it will work.
Old Feb 27, 2004 | 11:04 PM
Car: 86\92 Mutant
Engine: 355CI 430HP
Here is a picture of my Holley on my 350 motor. Car was origianlly a 1986 LG4. Note the position of the the throttle cable. Just beside where I have my lower throttle return spring located, is where the TV cable stud goes. In fact the stud for the TV cable is still installed...even though I have a 5 speed now.
Attached Thumbnails Kickdown cable wont hookup after new carb.........-carb-linkage.jpg
Old Feb 28, 2004 | 10:15 AM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
oh thanks i put the return spring where the sutd is supposed to go .
Old Feb 28, 2004 | 11:05 AM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
ok i have the same bracket as you from an 84 lg4 but my big problem is the kickdown cable is too short and cant figure out how to adjust it?
oh yea that $20 holley bracket is garbage.
Old Feb 28, 2004 | 12:13 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
I got it thanks again for the info.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
