Broken Shifter Or Somethin!! Need Help Asap!!
Old Apr 21, 2004 | 01:36 AM
dopplereffect's Avatar
Car: 91 firebird TBI
Engine: Three SLow Five. LO3
Transmission: MAN 5 SPD B0RG WARNER, 77MM, 2.95
Ok guys see if you can help me, first i was goin over some rail road tracks and i down shifted, then when i went to up shift it was stuck and would not move(the shifter) so i let it stay in second gear untill i get down to a safe block (out of traffic). so the car wont shift at all, almost as if theres a lock on there
so i turn of the car and i pull the shifter free. so i start the car up or at least attempt to and it wouldnt start unless i put in to gear. so after a little trouble it got goin, so i shift to first its fine, go to secondit has a tough time goin in but it goes. at third there is no third because thats where i got E-screwed. all of a sudden it will not go in to any gear
it will not get a gear i have no idea what to do. i dont think its the clutch because i dont ride it much and i didnt smell burning. im thinking its the shifter or linkage. i honestly dont know what it is and am more than likely have to replace it my self so if anyone knows that would be a giant help thank you.
Old Apr 21, 2004 | 11:53 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Your shifter should be fine. It sounds like a shift fork has gone south. Bad synchors will usually allow you to go into gear after you double clutch. Have you tried that.
Old Apr 21, 2004 | 03:16 PM
ok i just came back form autohell aka autozone and they didnt have it, so later on i will go to oreilly and if they dont have it i guess ill order it from jegs or summit or even year one unless someone else knows where i should go look.
Old Apr 21, 2004 | 04:36 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Well a shift fork is noth sowemthing parts places stock. You need to go to a tranny shop and have them look at it to be sure that that is your problem.
Old Apr 21, 2004 | 04:38 PM
yea thats what iu should do but it sucks because i have zero dollars and i am about to start the fire acadamy so i wont have money or a car for a while
no green
Jan 9, 2016 09:22 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
