putting a disc rear in my drum car.need help
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
i have a 92 rs 305 t-5.with drum brakes..im putting a rear from an 87 z28 with disc brakes in it and am confused about the making of the brakes work....do i need a differant master cyl and proportioning valve some have said yes but i know you guys will know..and if so can i use any or all of these parts from the doner car....thanks
Axle/Gears: 3:08
you mean keep my master cyl that i have on my car now with the drum brakes?will the pv off the 87 bolt up to my master cyl?
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
the proportioning valve will bolt up without a problem. It would be a safe bet to grab the prop vavle bracket and hard lines also, just so you know their won't be any fitment issues.
Car: 1987 Camaro IROC-Z
Engine: LB9
i'm in the process of doing this work myself, what needs to be modified on the back end of the car to get the brake lines routed?
Engine: LT1; LT1
hectre13
12-11-2023 08:14 AM
sailtexas186548
01-19-2016 12:21 PM
novaderrik
08-10-2015 12:44 PM
