New Delco 3-Wire Heated O2, 3 Wire Pigtail, TPI IAC Valve
Car: 1987 Firebird Formula
Engine: 305 LG4
AC Delco TPI/TBI Idle Air Control Valve new in box. Part#25527077, fits 85-92 305,350TPI, 89-92TBI. $40+shipping
AC Delco Heated 3-wire Oxygen Sensor new in bag. Part#25312179. $40+shipping.
AC Delco 3 wire pig tail new in bag. Part #12126012. $15+shipping.
Would prefer paypal.
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: New Delco 3-Wire Heated O2, 3 Wire Pigtail, TPI IAC Valve
Will the 02 convert my 92 Z 1 wire with just plug and play? Will the other stuff work on my BBK throttle body for a 92? How much for all it shipped to Malvern, Arkansas 72104
Engine: 305 LG4
I had a one wire also on my 87 bird that's why I bought the pigtail also. There are many threads on here about the conversion so you might want to double check to make sure it would work on your car, but basically one wire on the pigtail attaches where your current wire plugs in, one wire has to be grounded, and the third wire has to be spliced in so it is "hot" when the ignition is turned on.
As far as the IAC valve working with a BBK throttle body, I don't see why it wouldn't since it's a delco sensor, but you should give their customer service a quick call just to be sure.
All 3 items would fit in a small USPS priority flat rate box so it shouldn't be more than $7 shipping.
Let me know if you want them. Thanks!
How much will buy it all shipped to 72104?
