Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
smog pump delete
Old Mar 15, 2001 | 09:35 PM
ryantking's Avatar
smog pump delete
I have just recently put headers on my 1991 camaro RS (305 vin E) when i was doing this i decided to take out the smog equipment, its all out except for the somg pump, is there anywhere that i can purchase an bracket that would take the place of the somg pump ???
Old Mar 15, 2001 | 10:47 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Rip out the smog pump and get a shorterbelt. The new belt will go over the alt, straight down and under the power steering then going up over the waterpump back through to the crank then up to the AC and back.
Old Mar 15, 2001 | 11:12 PM
JETHROIROC's Avatar
Just check the technical articles section, the belt routing is all laid out in there like Mkos said.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, Accel coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Ruger P95DC, hot wife, new oil filter,
thick rubber floormats, towels in the seats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Mar 16, 2001 | 02:59 AM
Omar's Avatar
Smog Pump Delete Pulley (10186167)
1989 IROC-Z 5.7L
Old Mar 16, 2001 | 02:54 PM
Steve89GTA's Avatar
With the idea being to reduce parasitic(spelling?) loss, isn't it better to just go with a shorter belt instead of introducing one more item on the serp belt's list of chores?
Does anyone which belt to use? i.e. off another car?
Thanks!
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
Autometer Vac+Oil Temp
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
LittleFranks
Sep 17, 2015 12:22 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
