Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Shift kit
Old May 16, 2002 | 02:39 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
Shift kit
Which is the better for a 700R4? Transgo or B&M? Any pro's and con's would be appreciated.
Old May 16, 2002 | 08:26 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I've researched this, and as soon as I get some extra cash I'm getting a trans go, B&M don't seem to last
Old May 17, 2002 | 03:00 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
Is there a certain part that goes out on the B&M to make them not last as long? I just want to be sure my tranny and rear end can handle my new 350, don't want to have it torn up real quick.
Old May 17, 2002 | 05:28 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I don't know, search the tranny board, this has been brought up a couple times, I was one of them
Old May 22, 2002 | 11:19 PM
catinthehat's Avatar
I have the B&M shift kit for about a year now and i have had no problems with it yet (knock on wood)
Old May 22, 2002 | 11:39 PM
87GTA57L's Avatar
to mkae it a bit simpler, people can only offer opinions based on experience with both of the shift kits. I doubt there are any stats you could really find comparing the 2.
there is virtually nothing that really can wear out. They both only have valve body gaskets, a few springs and different spacers.
unless you know something about transmission's, I wouldn't recommend doing it yourself also.
Sure it'll be tough on your drive trrain, but that's a given!
I have the B&M stage III (drag version), and have had no prob's with it.
If you do decide to do it yourself, If you need help let me know, I've done a few.
later,
87GTA57L
Old May 23, 2002 | 01:51 AM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
I would second that suggestion to have someone do it for you. Find a good speed shop that does transmissions. I couldn't get any regular tranny shops (AAmco) to touch a modified transmission. I tried doing my own, it seemed simple enough, and ended up having to get it towed to the shop for them to do it right.
If you're feeling rich, or the tranny's got a lot of miles and/or hard launches on it, look in to getting a new servo, and new bands and clutch packs.
Oh, yeah, I've been running a B&M for two years now. No problems.
Old May 23, 2002 | 12:11 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
I know about Jack **** when it comes to a trans. Can a shift kit be installed from a garage or do you have to take it to a pro.
Old May 23, 2002 | 10:55 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
From transfixleo and probuiltautomatics from the Tranny board. TRANSGO is the only REAL shift kit. It fixes the problems with the 700R4. B&M masks it, they would never recommend it.
Old May 24, 2002 | 10:37 PM
IROCZ88's Avatar
The B&M shift kit has you drill holes in the valve body and replace the accumulator springs with a rod which gives you an extremely hard shift at any throttle. Real hard on equipment!!! Trust me, I put one in last year and now my tranny is toast!!
The transgo is an accumulated shift kit with a corvette servo that gives you a soft shift at part throttle and an f'n hard shift at full throttle. Basically the hardness of the shift is progressive. My new Pro-Built tranny has the transgo and that's the one I would recommend.
BTW, the B&M kit was easy to put in, they have great instructions and I had no problems at all. Not sure about the Transgo cause Pro-Built did my new tranny. (I'm puttin it in tomorrow!!!!)
Old May 29, 2002 | 12:36 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
Ok i'm gonna go with the TransGo, but I notice there where like 3 different "types?" on their site. I want the one with the Corvette servo. Can anybody help, like a part # or something??
Old May 30, 2002 | 10:03 AM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
I ordered mine from Dana @ probuiltautomatics, I would suggest calling him and let him know what you want the tranny to do and he will tell you what you need. I opted for the HD kit for my daily driven RS, my shifts are firmer but much smoother.
Old May 30, 2002 | 12:17 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
Do you have a phone number or do they have a website?? It would be much appreciated.
Old May 30, 2002 | 12:38 PM
vjo90RS8's Avatar
Car: 2002 Z28
www.pro-built.net
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
