Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
B+M console shifter for 91 camaro
Old Apr 18, 2001 | 08:59 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
gonna try installing one this weekend. i read the instructions last night they seem pretty much strait forward. was wonderin if they are any tip out there
thanks
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler
Soon to come .SLP Posi 323,Spohn LCA's and panhard bar,Ascd ram air hood, Z28 spoiler and grille,white guage faces.
Old Apr 18, 2001 | 12:10 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Its a pretty straight-forward operation. Its a PITA to get the shift indicator cable attached. i only put one screw in mine and it works just fine. Make sure you use red lock tight on all the mounting bolts. i had one of mine loosen up and it stipped the hole. Plus you cant shift it if the bolts come loose. Also be sure to put some anti-seize on the handle threads to keep it from galling. Should be able to get it done in under 2 hours. Thats pretty much it. Good luck man.
1988 IROC-Z L98
License Plate: STG KLR 1
Engine Mods:
Edlebrock TES Headers, Hypertech Chip, Flowmaster Muffler, Intake Airfoil, Removed MAF Screens, MSD-6A, MSD Blaster 2 GM Coil, bored .030 over, Other minor mods
Suspension Mods:
Lakewood Traction Action Lift Bars, Hal Rear Shocks
Trans Mods:
2,500 stall converter, Redline clutches,Heavy Duty Steels, Trans-Go reprograming kit , Heavy Duty 2-4 band, Corvette Servo, B&M Mega Shifter w/ Carbon Fiber Handle (looks sweet in a black car!)
14.104@99.66
"If you can put it on your car, its fair" Quote By Guido
Foundering Member of the Illinois Overkill Crew (IOC)
www.mfba.org
Old Apr 18, 2001 | 04:04 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It was straightforward for me, too. Take your time when you adjust the cable underneath the car... so many guys botch that one up because they hurry through it.
My only tip- I laid all the parts out in front of me, and went through the instructions. When a step called for a part, I put the part in a baggie, labeled it with the Step # of the instructions, and sealed it. Then, when I was in the car, all I did was grab bags of parts instead of hunt through a pile. Good luck!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Apr 19, 2001 | 09:01 AM
bbtaz97's Avatar
Car: 91 RS
thanks for the help guys.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Winchester1094
Interior Parts Wanted
Aug 19, 2015 05:01 PM
TheJoeY88
Aug 13, 2015 06:51 PM
