Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Anyone "slow down" with a TPIS PROM?
Old Apr 20, 2001 | 10:22 AM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
Are they really off on there programming with their Magnum PROMS for TPI? I actually had 7 more HP on a Dyno run when I installed the stock PROM back in the ECM. I was originally using a TPIS Level 4 PROM ($500). Any suggestions on better PROM burners?
1988 GTA 5.7L TPI Auto
355 ci. block,TPIS ZZ-9 Camshaft, SLP Headers, Borla Cat Back, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Apr 20, 2001 | 11:05 AM
mrirocz's Avatar
I slowed down after installing a Performance Resource chip. I got a scanner and monitored it at a full throttle run. It turns out that because the chip was advancing the timing so much that pinging occurred and the knock sensor was pulling out about 15 deg of advance. It absolutely killed the performance. I guess its my fault because I had already advanced my base timing so I just through in the stock chip again. I'll reset the timing and retry the chip soon.
Old Apr 20, 2001 | 12:29 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
The best prom-burners are the guys that do it themselves. For more details, read Trax's article on PROM-burning and scope out the DIY-PROM board. Ask Trax what the thinks about the TPIS (and other) chips. They're more worthless than an AFPR.
Greg Westphal
'87 IROC 305TPI/A4
Old Apr 20, 2001 | 08:14 PM
theformula's Avatar
Fastchip is good. But some of the chip burners on this board can do just as good a job.
I don't have anything TPIS on my car and I never will.
Old Apr 20, 2001 | 11:48 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I just got a fast chip and its slow as hell so its going back to ed.
Old Apr 21, 2001 | 12:47 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I'm with Greg on this. The BEST chip is ONLY available when you burn it yourself as only YOU will spend the time needed to tweak it to the max.
Prom Burning is a LOT EASIER than most people think and it's a lot of fun once you get into it. The coolest thing is, of ALL the things you can do to a car, its the easiest and cleanest thing to do.
If you invoke Highway Mode, the gas savings alone will pay for all the equipment and software very quickly. Definitely within a year and probably a lot sooner, depending how much you drive and the cost of gas (which seems to be headed in only one direction these days). Think about how much money you spent on your eprom, and you could have bought EVERYTHING including a scan tool and probably a couple trips to a dyno.
People don't realize that EVERY engine is unique and different. It is impossible for an eprom writer to burn you a "perfect eprom" just based on "mods installed". It requires a lot of "experimentation and testing".
Would you install a carb based on the "pre-settings" from the manufacturer? Would you install a distributor based on it's "pre-settings? Of course not! So why do people think that eproms are different? They needed to be "played with and tested".
Prodigious
Nov 7, 2020 09:23 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
stalkier
Dec 6, 2015 11:25 PM
Keith5
Aug 27, 2015 04:37 PM
Sanjay
Aug 12, 2015 03:41 PM
