Baer??
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
Nothing bad, just observation
I've installed Baer's kits several times. Instructions are detailed, parts fit, and systems work. Installed SS/Track13"/12" on my 92Z, then the SS/Track 13" fronts on my wife's 96T/A Ram Air. Everything was fine.
Only hitch was after I had installed the system on my car, I decided to upgrade to the newer PBR calipers that were black finished with silver Baer logo machined into the outer side of the caliper. Unfortunately, nobody caught the design change from PBR that cause a slight interferrence between the heat sink fins on the caliper and the ID of the 17" rims. The old template they used to have didn't account for the slight change in PBR's caliper so I saw no problem when checking with the template. A little grinding on the heat fins gave me the required clearance.
84 TA NV
Sep 6, 2015 08:02 PM
