Help needed! Rebuild kit, cam ect....
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
I am thinking about rebuilding my L98. Can anyone tell me a good rebuild kit (to go to a 355) to up my comp ratio to 11:1, and give me at least 330 HP in the motor alone? I will also need a cam to match and even some good heads for cheap (better then the L98 **** heads). I am looking to do the compleat rebuild for around $1800. Is that impossiable?
25th Anniversary Z28
Check out my car at:
www.mylecdekmat.com/mgofast.htm
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
A few
PAW @ www.pawinc.com
Powerhouse @ www.enginekits.com
Summit @ www.summitracing.com
I'm sure you will get a few other places listed from others too.
AJ
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
AJ
air cleaner
-B&M TransPak
-Jet Stage2 Chip
hectre13
Dec 11, 2023 08:14 AM
