supercharger
supercharger
I have an 86 Z with a 350 what kind of power increase on average would i get with supercharger? what kind are you guys using? would i need a 4th Gen tranny? whats your opinion on superchargers?
If I could turn back the clock on my car I would have bought a 305 car with a 5 speed (and thicker head gaskets) and dropped a blower on it. Less engine hassles with this. Stick to a centrifugal sytle like a Paxton or Powerdyne.
With the stock 6psi of boost from a Paxton your 350 (bone stock) should make about 320hp. To raise the boost all you have to do is swap the drive pulley for a smaller one. 10-12psi should get you 360hp easily.
As for other parts. You'll need bigger injectors, stronger u-joints, and a driveshaft loop. A well built 700-R4 will handle 400hp. The stock lower end will handle the horsepower if you don't beat on it all the time.
1986 Trans Am
carbed 350 - .30 over with 9.75:1 comp.
+- 315hp/390ft lbs.
700-R4 with 2500 stall
3.27 (ick!) gear
SLP 1 3/4" headers w/MAC catback and cat.
96 5 stars
SFC's, braces, arms, and a bunch more expensive stuff
no timeslips yet
1986 Trans Am
+- 315hp/390ft lbs.
3.27 (ick!) gear
96 5 stars
no timeslips yet
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Go for Vortech or ATI....Do a search on the board and you will find alot of post about them.
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods, a Canfield headed 383 in the works!! ready May 2001...
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
toronto formula
Nov 10, 2015 06:17 AM
