Formula Wheels
Formula Wheels
My wife had my wheels rotated as a FAVOR for me. I don't know if they put the correct wheels on the front and back. Can anyone tell me which offset goes on the front and rear? Right now the ones with the @1" lip on the outside are one the front and the ones eith the @1/4" outside lip are on the rear.
Thanks,
Fish
89 Formula 63000 miles.
Thanks,
Fish
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
i think they are backwards...
the ones with the narrow lip should go on the front...
if they are on wrong... the tires will rub when turning the steering wheel...
later,
Chris
later,
Chris
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
When George brought his car to Wall Mart for tires (First mistake) they put his 16" honeycomb wheels on backwards, and the calipers chewed up the inside of the front wheels.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
The bigger lip goes in front 1/4 goes in back Positive. Even says on the back of the rim.
89 FORMULA 350 Edelbrock Cat-Back March Pulleys
Accel Cap ,Super Coil SLP Airfoil K&N Filter 180 stat , Fan Switch
Taylor 8mm Spiral Pro,TB Bypass ,Energy Sus bushings ,Hotchkis STB ,MSD 6AL ,Edelbrock TES's ,Hi Flo Cat ,Crane AFPR ,Shiftkit w/Hurst lockup ,1/4 time 14.4@98
