Superchargers...
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Superchargers...
Does Anyone know of a supercharger for my 87 Formula, Most are for 88-92...
87 Formula 5.1 converted to TPI Yellow/Black
SLP cam, headers, cat-back exhaust
Ported & polished TPI intake
Gil Younger (no yo-yo) Shift Kit
Aluminum Driveshaft
3.73 Posi gear
Baer 12" brakes 4 wheels
Hotchiss strut tower brace
South side machine frame connecters
Custom reinforced control arms and pan hard bar.
Custom Leather interior
87 Formula TPI (5 Speed) Yellow/Gray STOCK
83 Camaro (Parts)
83 T/A (parts)
www.3rdgenformula.com
Aluminum Driveshaft
3.73 Posi gear
83 Camaro (Parts)
83 T/A (parts)
You can use one designed for later cars if you convert to serpentine belt, including the bracketry and correct accessories.
1 Post
Car: 2000 Trans Am
Paxton makes a kit for 88-92 but frankly, they arent worth a broke **** . I had one and ended up selling it after having it rebuilt three times.
My advice would be like the 1st reply. Convert your accessory setup to serpentine and buy a kit from Vortech or ATI. Thats what I did.
-86 IROC
S-Trim, Speed Pro, AFR
this years goal: 10.50 @ 130+ mph
-=ICON Motorsports=-
-86 IROC
I have heard some BAD things about Paxton from other reliable sources as well....
I have SOME of the serpintene set up from an 89 Car, all I have is the right side bracket for the Alt & A/C.
Aluminum Driveshaft
3.73 Posi gear
83 Camaro (Parts)
83 T/A (parts)
Aluminum Driveshaft
3.73 Posi gear
83 Camaro (Parts)
83 T/A (parts)
Car: 2001 Camaro SS
Engine: Almighty LS1
Procharger's are your best bet ...
I'm getting the one they've got for the carburetors at the end of the year
