Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Pulleys
Old Jan 21, 2003 | 03:01 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
Pulleys
i'm thinking about TPIS pulleys,
i've heard good and bad things about pulleys i wanna know what everbody else has to say
89 iroc 305tpi
Old Jan 21, 2003 | 04:04 PM
BRIrocZ's Avatar
Car: 97 Z28
Transmission: A4
Pulleys are cheap and easy to install. I have the March 2pc. I've been running mine for almost 2 years and only twice has my battery gauge dropped to the red. Remember your also slowing down the water pump too.
Old Jan 21, 2003 | 04:15 PM
383 rocket bird's Avatar
I also have the march two piece and it gives me trouble with accessories on. It is at the point where i can't use my running lights without trouble. My recomendation is to not run under drive pulleys unless you have a charging system upgrade such as a 140 amp alternator like powermaster or install the iceberg kit in your own alternator. Hope this helps
Old Jan 21, 2003 | 06:13 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
double post, oops
Old Jan 21, 2003 | 06:14 PM
ryn28's Avatar
Engine: Chevy ZZ4
March makes 2 different kits of the two piece underdrive pulleys, or at least the used to. Awhile back I had the regular kit I guess you could call it and sometimes my volts would go pretty low with alot of acc. on even with my 100amp alt. Now I have what they call the Power and Amp series. The alt. pulley is ridiculously small which makes the alt. spin faster with the smaller crank pulley. Since having this setup my volts have dropped only slightly with the headlights and acc. on.
Steel pulleys:
Set#4000 is the performance 2pc. for your car
Set#4400 is the power and amp
Aluminum pulleys:
Set#4010 is the 3pc. performance set
Set#4410 is the 3pc. power and amp
Above info from:
http://www.marchperf.com/pg1.html
Old Jan 21, 2003 | 08:57 PM
MdFormula350's Avatar
they look good, but i am also not sure if i went to get them or not.
Old Jan 21, 2003 | 09:00 PM
Engine: peanut LB9
thanks i didn't know that there was two differnet sets,
Old Jan 21, 2003 | 09:10 PM
Engine: peanut LB9
do i need to get a new serpine belt or will the old one fit one there
Old Jan 21, 2003 | 09:49 PM
A new belt is required for underdrive pulley set ups. I took off the March alternator pulley and went back to my old one and was still able to use the belt i bought with ther March set.
Old Jan 22, 2003 | 12:11 AM
Benny's Avatar
Once again, like an air foil, this is a mod that does nothing, bought some, sold them one month later.
Old Jan 22, 2003 | 02:10 PM
Every little bit helps.
Old Jan 22, 2003 | 03:41 PM
Engine: peanut LB9
thanks, i'm gonna order them friday. i'm gonna get the march power and amp pulley set along with a new belt, i already have a 55/135 amp alternator.
i dunno if the 55amp setting will be good anymore, so i will have them up it to 70amps, do u think that will be enough to run my basic elecricaly system, just what she needs
Old Jan 22, 2003 | 05:49 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I believe Zoop and Concept One also make pretty good pulleys, or so I've heard. I don't know of anyone with them though.
Old Jan 22, 2003 | 09:14 PM
jd13's Avatar
I have to heartly disagree with that. I don't think I run 13.7 @ 100 mph with just headers/exhaust. I think these are a great mod, even better because they aren't real expensive.
If you have a stereo system, plan on replacing your altenator down the road because it will go bad.
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
evilstuie
Sep 24, 2015 02:31 AM
