Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Looking at CompCams XE268
Old Jun 11, 2001 | 09:42 AM
erummel's Avatar
Car: 92 Z28
Engine: aint got no engine right now
Transmission: need one of those
I am looking at using this cam for my L98 and was curious if anyone new what the price was for the cam, cam/lifter kit, and the cam/lifter/1.6 rocker kit (if one is offered)? Also, has anyone used this cam and if so, what were your impressions?
Eric
Old Jun 12, 2001 | 10:23 AM
brian86Z's Avatar
i use this cam on my carb'd 383. it has very good idle quality and is good through the hole rpm range, i would recomend it. for my setup i wish i would have gone with a little bigger cam.
brian
Old Jun 12, 2001 | 02:14 PM
erummel's Avatar
Car: 92 Z28
Thanks for the reply.
Is there anyone who has used this cam with a TPI or SuperRam set up?
Old Jun 12, 2001 | 06:57 PM
JJ's Avatar
JJ
I used to have one in carbed 350. The one I had was not a roller cam however. If there is a roller cam XE268 variation (I thought I heard they were going to make something similar for roller) AND you had intake work it would be OK, mine pulled to 6k easy, really strong from 3k up. The LS was 110 on mine, this might not be good for the tpi also.
Old Jun 13, 2001 | 10:39 AM
erummel's Avatar
Car: 92 Z28
JJ the lobe seperation of the TPI version of the XE268 is 114 so I should not have a problem.
Has anyone else used this cam before preferably in a TPI application?
Eric
Old Jun 25, 2001 | 04:28 PM
Sharky's Avatar
Comp Cams XE268 is talked of highly in Chevy High Performance magazine. I've seen them use it in a couple mild 350 engine build ups. In one instance swaping the stock cam of a goodwrench 350 mouse to a XE268 made a difference of a 100 HP!
As it is, I'm considering this cam for my setup, but I'm not sure how much is would cost to swap cams. Probably not cheap.
Drew Veeneman
87' Camaro
Jasper Class II 350 (.3 over)
World Products S/R iron cast heads
Stock auto 700r4
Snail like 2.73 gears
3" round K+N Air Filter
Road Demon 625cfm
Edlebrock Performer Intake
Edlebrock TES Headers
3" Cat+Flowmaster
Ugly olive drab camoflauge paint job
Check Out Sharky at https://www.thirdgen.org/rides/index...ew&rideid=3002
Old Aug 16, 2002 | 04:56 PM
maverick351ci's Avatar
Car: 1985 Firebird
lil insight
i usesed a massive cam in my stock 350 tpi setup still running the 305 chip and injectors heres the spects on my cam that i had in it
it was an erson race cam grind number e110521 hi flow2h 1.5
it goes as followed
intake lift .472 intake duration 306
exhaust lift .472 exhaust duration 306
intake opens 45 deg closes 81 deg
exhaust opens 81 deg closes 45 deg
overlap 90 deg
intake lobe c/l 108 deg
lobe sep. angle 108 deg
i was running 1.6 crane long shot roller tip rockers so i had .504 lift i belive
it ran like a top but i had no brakes i had to install a vacumume canister for the brakes and then i still had to hit it to nutral and tap the gas to stop quickly
Old Aug 16, 2002 | 08:21 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
No way, not on those stock heads of the Goodwrench motor. I got way lesss than that on DD2000.
I love the cam, installed it a week or so ago. Nice lopey idle, I'll have GTech results some time.
Old Aug 16, 2002 | 08:42 PM
darbleinad's Avatar
Car: 84 Trans Am
hey Mark, why dont you take your car to the track.........instead the stupid g-tech......
Old Aug 17, 2002 | 07:34 AM
QATransAm's Avatar
Is the XE268 to big for a 305??? i'm looking at the XE262 but i was wondering if i could squeeze by without any problems with the 268....any opinions? thanks
Old Aug 17, 2002 | 08:48 AM
Car: 99 Formula
Axle/Gears: 342
I hear the 268 is too big for a 305, and the 262 seems to be a better choice.
I'm not taking the car anywhere till I get these rockers adjusted, the roller ones slid off cause they weren't SA.
Old Aug 17, 2002 | 09:26 AM
QATransAm's Avatar
Thanks man, i think i am going to go with the 262, i don't want any drivability problems, and i want the car to run....and by the way good luck with your car, i hope you get everything done perfectly soon! nice car
ChaseDale3and8
Sep 1, 2015 01:49 PM
RacingGreenSC
Nov 14, 2001 05:00 PM
90Form350
Aug 17, 2001 08:22 PM
