SLP.... or anyone with header knowledge
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
i guess this question could apply to anyone with headers and air conditioning. i have an 86 IROC w/ a/c on the driver side. has anyone gotten headers to fit without modifying the a/c bracket? Could i survive without this bracket. The bracket goes right over the manifold. I just called home and my headers have arrived with the install kit and cat adapter but I bought the kit that doesn't come with the bracket. He said the $110 kit was for A.I.R. and I didn't order a.i.r. What should I do?
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
None of the install kits come with brackets. All that comes included, from memory, is some hose, pipe clamps, and header bolts. You will need to use the same brackets that are there. This means that you will need to use a few of the bolts that came off of the manifolds, like the double threaded end bolts. I could be wrong but I think all you will need to do is get some rubber hose so you can make the connections to the air fittings. Just get 2 ft of 5/8 or 3/4 inch hose and make the connections longer and you might be OK. Any body else????
Good Luck!
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&W subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
Good Luck!
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Mine came with a bracket that bolted to the header. Nice heavy one. of course I bought the ones that was for A.I.R..
John
87 Formula Yellow/Black
Engine & Transmission
.040 over 5.0 converted to TPI, 9.5:1 Compression, SLP Cam Dur 206/212, Lift 480/487, Cent Line 112, SLP headers, SLP cat-back exhaust, K&N Airfilter, Modified Stock cold air intake, Ported & polished Stock TPI intake, Holley Adjustable Fuel Press regulator, AC Rapidfire Spark Plugs.
Gil Younger (no yo-yo) Shift Kit, Aluminum Driveshaft, 3.73 Posi gear
Suspension & Brakes:
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Hotchkis strut tower brace, South side machine frame connectors, Custom reinforced control arms and pan hard bar.
Interior:
Custom Leather interior, CUSTOM Yellow Gauge Faces, Kenwood Receiver, Pioneer Speakers, Kicker Substations, Kenwood 10 Disk Changer, Pioneer Amp.
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
John
Interior:
83 Camaro (Parts)
83 T/A (parts)
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
why didn't you use yours? is it the slp bracket? how fast can it get here????
[This message has been edited by yellowiroc2 (edited August 03, 2001).]
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
it is the SLP part.i do not have a/c on my car so i didnt need it.I can have it shipped by monday probably 3 day air..let me know as soon as possible.If you want email me your adress so i can ship quick at : onebad82z@excite.com
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
[GA] Shorty headers
Night rider327
Sep 16, 2015 02:20 AM
