MSD Digital 6
MSD Digital 6
Just want to know if you guys have any opinions on the MSD Digital 6. Does anyone have it? Was it an easy install? Any useful informtion would be appreciated. I am going nitrous and want the ignition for a better spark and for the ever so crucial timing retard. Do you know if it can be controlled in the car or does it automatically pull timing when you hit the N20?
"Though I cruise through the valley of Rice I shall fear no turbo, for torque art with me."
--Cullan Hooley
1985 IROC-Z w/T-tops, 305 out and 350 L98 TPI engine in, Hooker Super Comp Headers, 3" Hooker Super Comp Cat-Back, 3" CatCo Cat, Rebuilt TH700R4 with Shift kit, 2,800RPM Torque Converter, 3.73 Richmond gears, Auburn differential, Accell SuperCoil, Accell 8mm racing wires, BBK AFPR, Homemade Ram-Air (thanks to Andris Skulte), MAF screens removed, Dropped A/C, Dropped A.I.R, TB coolant bypass, Hurst Dual-Gate Shifter, SLP Air Foil, K&N filters, Holley performance fuel pump, Spohn Subframe Connectors, Re-located Spohn Lower Control arms, and more to come.
--Cullan Hooley
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I is really nice. I would recommend it and it wasn't too bad to install if you understand a small amount about wiring. I could probably tell you how to install it over the internet.
1991 Firebird
350 L98 (was a 305 TBI)
T-5 transmission
Edelbrock TES and cat back
Accel manifold
NOS
subframes
jegster torque arm
MSD Digital 6
AFPR
Lakewood lcas
Hurst linelock
SLP cam (206 212 .480 .486)
relocated battery
cold air
Hypertech chip
centerforce df clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
a/f gauge
autopower rollbar
12.44 @ 114.63 juiced uncorrected
13.549 @ 102 non juiced uncorrected
1991 Firebird
T-5 transmission
Accel manifold
NOS
subframes
jegster torque arm
MSD Digital 6
AFPR
Lakewood lcas
Hurst linelock
relocated battery
cold air
Hypertech chip
AFR 190s
a/f gauge
autopower rollbar
I have the Digital 6 Plus in my 'Roc. Needless to say this is the best ignition out there on the market when it comes down to features for the buck. I believe it is the light blue wire or pink wire(one of those) that you supply 12V to, (hell the wires are long enough just tie it into something that gets 12V) thusly it activates the Step Retard for Nitrous. You determine how much timing it pulls out via the dial indicators that allow for 1* and .1* increments of timing retard for your application. So choose how much timing you want pulled out and it'll do the rest for you. Now that's what I call good tuneable insurance.
Brian P
89 IROC-Z 355
Brian P
89 IROC-Z 355
I have a Digital 6 box for my car but haven't installed it yet. One of my friends has MSD Digital 6 boxes in both of his rides. He is the one that convinced me to buy one after my Crane HI-6 died for the 3rd time. I have only heard good things about this ignition box.
1986 IROC, fully loaded, Mini Ram'd 383, Art Carr 700R4, Accel DFI, 12 bolt rear, etc, etc......
RedLeader289
May 28, 2019 01:47 PM
