stalling non AIR headers
Car: 89 Iroc Z28
Engine: 312ci
i'm putting on some headers that don't have AIR injection. i was just wondering if it was ok to yank off that hose that connects to the air thing on the old manifolds. i also wondered if i would have to do anything else to the smog system to run non air headers. thanx
Car: '89 rs convertible
Engine: ls1
Axle/Gears: 3.73 posi
I just swapped the 305 for a 350 in a'91 Z28 and I installed non-AIR headers. I removed the hoses,pump,and diverter valve. I wanted to keep the O2 sensor(obviously)and found K&N sells a weld-on bung that could be put on Y-pipe and so far,it looks like I will have to make pipe.You really need to check local smog laws,because the car might not pass inspection.HOPE THIS HELPS.
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
