Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Driveshaft loops
Old Aug 12, 2003 | 11:41 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Driveshaft loops
Who has them and what kind did you buy?
Are they hard to install?
I've seen universal ones that require drilling but you don't have to disconnect the driveshaft.
The Spohn one looks nice but is quite a bit more $$. I believe it connects to the crossmember but does require disconnecting the driveshaft.
Old Aug 13, 2003 | 12:11 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I have the Spohn loop but haven't installed it yet. Its only 4 small bolts holding the d/s on. Alot easier then trying to drill holes in the floorpan. You have to use a poly tranny mount with the spohn loop tho.
Old Aug 13, 2003 | 07:47 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Why do you have to use the poly mount?
Old Aug 13, 2003 | 08:09 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
lakewood sels one just for our cars too
Old Aug 13, 2003 | 11:05 PM
Because it uses 2 bolts into the mount to hold the loop onto the xmember. The poly mounts have 3 bolt holes on the bottom, stock rubber just has a stud.
Old Aug 14, 2003 | 01:23 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Well I already have a poly trans mount so that may be a better reason to get the spohn one. A little pricey though. What did you pay for yours?
Old Aug 14, 2003 | 01:49 AM
I paid $75.
Old Aug 14, 2003 | 07:46 AM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
I used this one. It fits like a glove and my 4" Mufflex exhaust system clears.
Old Aug 23, 2003 | 11:19 PM
L98FORM89's Avatar
Car: 1989 Formula 350
Engine: 355 HSR
Transmission: Rossler 700R4
Axle/Gears: 9 bolt/3.27
Had my car apart and found out the Spohn D/S loop wouldn't clear my exhaust(dual cats/dynomax and 3" flowmaster force two). That was my case though.
Old Aug 23, 2003 | 11:42 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I have the Spohn, no problems and very easy install.
Old Aug 26, 2003 | 09:11 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
I built this one to bolt to my tremec....
Old Sep 3, 2003 | 03:35 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
wingnut, how is the installation on the Jegster loop? It looks like it would require the driveshaft to be disconnected, but I will be getting my tranny rebuilt soon so it will be disconnected anyway. Where does it bolt up?
Old Sep 3, 2003 | 08:05 AM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
Yes, I had to drop the driveshaft. It bolts up near the front of the driveshaft, just behind the front U-joint. I can't remember off hand where exactly the bolts are inside the car. I think they are just behind the front seats. I installed a new torque arm kit (also Jegs) at the same time, so I already had the front seats and carpet out of the car. I don't think that the seats have to come out to install just the loop. I'll have to look when I get home.
Old Sep 5, 2003 | 04:28 PM
CHRISMAN2000's Avatar
Car: 1991 Camaro Z28
Engine: 350 L98
I wanted to get a driveshaft loop too. When I saw the price of the lakewood loop I thought I was dreaming. It was way cheaper then spohn. I e-mailed them and asked what was involved in the install. They said. Remove the seats, carpets, cat heat shields. Then drill holes in the floor pan.
I'm waiting for a 9" rear so I can get a spohn tourqe arm with a loop. No way am I going to drill holes in my baby. Plus spohn made the loop into an ovel to help with clearence. Sounds like a winner to me.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
loud91rs
Oct 5, 2015 10:05 PM
luvofjah
Sep 26, 2015 08:28 PM
Nick McCardle
Sep 10, 2015 08:36 PM
