Autometer?
Autometer?
If i bought a 200 mph 5" speedo would it fit right into the dash? How does it hook up?
1988 RS Camaro
V8-5.0L-305-L03
700R4 Auto Trans.
Flowmaster Exhaust 80 Series
K&N Air Filter
Very Mild Cam
180 degree Thermo.
http://www.geocities.com/eternalcamaro/
1988 RS Camaro
V8-5.0L-305-L03
700R4 Auto Trans.
K&N Air Filter
Very Mild Cam
180 degree Thermo.
Car: 1986 Z28
Engine: 355
Transmission: th400
As far as it going into the dash, No it will not go right in.
as far as it hooking right up No it will not
the bezel sticks out from the plastic, where as the stock one is in the cluster.
you would loose your VSS signal if it's an older car, and drive the computer nuts.
It doesn't hook into the factory printed circuitry, nor does it use the factory speedo cable end.
Would a Electronic speedo work since it connects right up to the VSS?
1988 RS Camaro
V8-5.0L-305-L03
700R4 Auto Trans.
K&N Air Filter
Very Mild Cam
180 degree Thermo.
1988 RS Camaro
V8-5.0L-305-L03
700R4 Auto Trans.
K&N Air Filter
Very Mild Cam
180 degree Thermo.
Car: 1986 Z28
Engine: 355
Transmission: th400
Not on a cable driven model.. in the factory speedo,the cable plugs into the back of the speedometer, with the VSS being attached to the speedometer, the cable runs right through it.. as far as i know there's no way to get it off and rig it to the new unit..
It's always SOMETHING
Hotrodboba400
Dec 10, 2019 07:07 PM
ambainb
Apr 25, 2016 09:21 PM
90formulaVortec
Sep 8, 2015 12:42 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
