Stealth RAM
Stealth RAM
I have an 88 GTA, want to put a stealth ram on it...but first, 1 would it fit my stock heads, and 2, would I be able to use my sotck injectors and fuel rail and throttle body??
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Yes, Yes, No, Yes.
The SR will fit your stock heads. It can also use your stock injectors. Now if you've done ANY research on this, everything specifically states that your stock fuel rails will not work. Lastly, your throttle body will work just fine.
Try checking the TPI board also, I know this subject has had a lot of activity and there was a sticky on it that should give you all the info that you need or will be needing.
Hope that helps.
Hope that helps.
